Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: CNC Drag Knife
Old 12-06-2012, 11:52 AM   #1
No idea what I'm doing
Default CNC Drag Knife
This may not be of use to many, but I thought someone might find it interesting.
I've wanted a CNC Drag Knife for quite awhile. I figured it would come in handy for cutting thin plastic and paint masks on my mill. Most I've seen are in the $100 range, and the replacement blades are about $15.
Then I found this website and thought this was just what I wanted. Something a bit heavier for cutting thicker materials with an inexpensive blade:
Drag Knifer for CNC routerDonek Tools
Unfortunately he wants $230 for one . I searched around and found this forum where someone made their own (scroll down a bit for a picture of what I found for inspiration):
Vectric Forum • View topic - Knives to cut foam core board?
I fired up the Prototrak during lunch and made one for myself. I wanted the blade at 60 degrees, so mine is a bit different. I'll be trying it out over the weekend. Most are spring loaded and use ball bearings, but mine does not. I'm not worried about the spring too much, and I can unhook my motor from my spindle and it turns freely.:
C*H*U*D is offline   Reply With Quote
Old 12-06-2012, 05:29 PM   #2
Default Re: CNC Drag Knife
so it's sorta like a plotter cutter? When I worked at Middle River Aircraft Systems, they had a CNC plotter for cutting the pre-preg carbon fiber. the cutting blade looked like a HD exacto knife.
Nice work on the machining.
BigSki is offline   Reply With Quote
Old 12-06-2012, 07:22 PM   #3
Pretty much the same idea. I've been wanting to cut thicker styrene with a consistent result, so I decided on doing it on the mill. The girlfriend is gone for the weekend, so I have a bit of time to play downstairs.
Old 12-07-2012, 11:50 AM   #4
I've wanted to build some type of cutting rig that was based on an old drafting table, something with guides for the X and Y movement.
Old 12-07-2012, 01:20 PM   #5
Suck it up!
Duuuuuuuude's Avatar
Whats the spindle speed on that puppy?
Duuuuuuuude is offline   Reply With Quote
Old 12-07-2012, 01:50 PM   #6
Zero
Old 12-07-2012, 01:52 PM   #7
Suck it up!
Well that's no fun at all.
That is a pretty nifty idea though. I might have to make one too. What gets placed underneath the material you are cutting?
Old 12-07-2012, 02:01 PM   #8
I'll probably use a large sheet of plastic. I've seen some people use wood or laminate. As long as it's flat, it should work.
Old 12-07-2012, 02:02 PM   #9
Oh that's sweet, I used to have a sticker cutting machine that had a miniature version of yours.
rangercat23 is offline   Reply With Quote
Old 11-25-2013, 04:10 AM   #10
I too need a Dragknife and I too found the Donek item but living in the UK there is shipping costs and import tax AND Value Added Tax!!!! so I need to find a solution like you have. How did it work out?
Thanks
keithstanley is offline   Reply With Quote
Old 04-19-2014, 07:56 PM   #11
Question Re: CNC Drag Knife
can this knife be used for engraving on brass ?
thank you
Richard Westerfield
richwest70@gmail.com
richard westerfield is offline   Reply With Quote
Old 04-19-2014, 11:53 PM   #12
No. The knife does not have an rpm and cannot achieve the cutting mechanics of engraving.
You will need this
Anatomy of an Engraving Cutter
wings_of_fire is offline   Reply With Quote
Old 04-20-2014, 08:02 AM   #13
You will need this
Correct. This is designed to be dragged along with the blade cutting the material...much like the wheels of a shopping cart follows the direction you push it in.
They also have spring loaded, diamond point engraving tools like this:
Diamond Drag Engraving Bit for CNC Machines - Use Your CNC Machine to Engrave Metal, Plastic, Glass, and Granite - WidgetWorks Unlimited
Old 04-21-2014, 03:27 AM   #14
Never used or herd about diamond drag engraving until now. That is nice.Thanks, learnt something new
CNC Drag Knife - Similar Threads
scx10 honcho no need for DRAG BRAKE?... already has drag... yellowpasta2000 Axial SCX-10 21 01-23-2010 09:28 AM
Got Knife??? raytard Chit Chat 7 08-24-2006 09:44 PM
