08-05-2014, 07:22 AM | #1 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
| Need some Lathe work..
The shop near by doesn't have time for my small job... or so he says. I have a small job needing to be done.. need a 1.5" alum rod turned down to 1.490. Drilled 5/16". 3 sections 3/8" thick parted off. The last part of the rod now drilled 3/8" Anyone here willing to do it for me and not charge an arm and a leg for it ? Thank you. |
08-05-2014, 10:12 AM | #2 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
| Re: Need some Lathe work..
You will probably have to start with larger material, .010" isn't much to take off an extruded shape.
08-05-2014, 10:36 AM | #3 | |
| Re: Need some Lathe work.. Quote:
08-05-2014, 04:05 PM | #4 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
how critical are the dimensions on this part I am wondering. I maybe able to pull it off... if the tolerances aren't to crazy |
08-06-2014, 10:22 AM | #5 | |
And by 1.5", is that its current length and you were looking to get {4} 3/8" thick washers out of that? (with all kerfs being taken from the last piece) If that's the case, do you really need them 3/8ths? 'Cause my guess is that last piece'd be mighty thin. | |
08-06-2014, 04:22 PM | #6 | |
08-06-2014, 08:03 PM | #7 |
Mine is .120" wide
08-06-2014, 08:18 PM | #8 |
Well my bar is 3" and I Need two 3/8" the disk. Whats left over drill out 3/8" bit. And I guess sanding it down would be better to get the 1.490" ? |
08-06-2014, 09:11 PM | #9 | |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
.010" is just enough to scratch the surface and show how out of round the stock is. Last edited by Lentsnh2012; 08-06-2014 at 09:14 PM. | |
08-06-2014, 10:12 PM | #10 |
Ok I feel like a real dumbbell. . Found my notes. Rod is 1.50" extruded 6061 The tube it needs to fit into is 1.490". I removed the old ones by banging them out with a broom handle so they are a snug fit but not needing a 15 ton press kinda fit.. lol Sorry for the mix up on the numbers as I posted off the top of my head.. |
08-06-2014, 10:56 PM | #11 |
I'm assuming that the 1.490" is the inner diameter of the tube? Just FYI, stick the male piece in the freezer for a few hours it'll shrink up enough to help it to into the female piece. The job doesn't seem like a big challenge at all- just a couple hours on the lathe. Just to get this straight, you're wanting the tube and rod to be cut at every 3/8th"? |
08-06-2014, 11:02 PM | #12 |
Just the rod.. it's 3" long.. cut off two 3/8" thick spacers with 5/16" hole. The left over drill out with a 3/8" bit. But it has to be drilled on the lathe so to be centered. |
08-07-2014, 12:07 AM | #13 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
Have you found anybody to do this for you? If not I can do it easily. Really if you cover shipping both ways that's good enough for me. It won't take me more then 1/2 hour. Let me know
Need some Lathe work.. - Similar Threads | ||||
Will a micro 30A ESC work on a lathe motor | chris_140 | Electronics | 9 | 12-08-2007 09:38 PM |
lathe work pretty please! FAST! | RCMFMaxxMan | Chit Chat | 1 | 09-10-2005 05:57 PM |
