Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: sanding....help please!!!!!
Old 11-24-2006, 11:31 PM   #1
snook's Avatar
Default sanding....help please!!!!!
:-( hey guys i had a freshly painted hi-lift body then i rolled it hard and now its all scratched....I used 180 grit sandpaper to sand the place were the scratch was....but it ended up putting more scratches onto the body...so i tryed to use 150grit sandpaper to sand out the scratches but its not working....help on what grit to use..:-(
snook is offline   Reply With Quote
Old 11-24-2006, 11:35 PM   #2
go to your hobby shop get mutiple grits of sand paper. and go up in grits, the final grit you finish with with be super fine and barely feel like sand paper.
I'm a bit tired but I will find you a site in a few minutes.
Shaun is offline   Reply With Quote
Old 11-24-2006, 11:35 PM   #3
So, you scratched it with 180 grit.........................then tried a rougher grit
Get some paper with X00s of grit (bigger the number, lighter the grit). Get some 200, 400, and 600+. Start softly with the 200 to try to smooth out some of the damage you have made, then work your way up through various grades.
Robb is offline   Reply With Quote
Old 11-24-2006, 11:38 PM   #4
Ok, start back with your 150 grit. after you do that, 280 grit, 320 grit, 400 grit and finish with a 600 grit.
Old 11-25-2006, 03:16 AM   #5
MWRCA'er
Mnster's Avatar
Your going to want to pick up some sandable filler primer. You will probably need something to fill in the scratches. Then start at 400 and work your way up to a 1000 or more.
Mnster is offline   Reply With Quote
Old 11-27-2006, 02:02 PM   #6
~The Scale Shop~
STANG KILLA SS's Avatar
get 220 grit, 320, finish with 400 grit.
STANG KILLA SS is offline   Reply With Quote
Old 11-27-2006, 07:45 PM   #7
snook's Avatar
just sanded it and painted it and it looks great......thanks for all the helpful comments
Old 12-24-2006, 11:12 PM   #8
useless without pics
sack is offline   Reply With Quote
Old 12-30-2006, 05:29 PM   #9
400 grit and wet sand it.
md99taco is offline   Reply With Quote
Old 12-30-2006, 08:21 PM   #10
i do a lot of wet sanding and buffing and i always stat out with 1000 grit.and end up with 1500 or 2000. you gotta be carefull on single stage paints.
JEFF THE JET is online now   Reply With Quote
Old 01-02-2007, 12:19 AM   #11
pictures would be nice dude just wanna see how it turned out
rustler421 is offline   Reply With Quote
