11-23-2014, 10:04 AM | #1 |
Pebble Pounder Join Date: Jun 2012 Location: upstate,ny
| Chinese welders
Anybody know what polarity the Harbor Freight or Tractor Supply wire feed welders use? Thanks
11-23-2014, 11:51 AM | #2 |
Rock Stacker Join Date: Oct 2014 Location: Indiana
| Re: Chinese welders
The polarity should be reversible. I have an older 120volt Snap-On welder and when I went from flux core to solid wire, I had to reverse the polarity. It's as simple as switching a couple wires inside the welder.
11-23-2014, 05:58 PM | #3 |
| Re: Chinese welders
It's a friends welder,I took covers off it & saw shrink wrap on the cables with some kind of connection. I'll have to ask him if he wants me to take it apart & reconnect.
11-24-2014, 07:37 PM | #4 |
Pebble Pounder Join Date: Dec 2012 Location: portland
| Re: Chinese welders
Flux core is run on reverse polarity. Hard wire is run on straight polarity. If it is only able to run Flux core, reverse polarity. If it can run both types of wire, it should be able to be switched inside the welder.
11-24-2014, 08:41 PM | #5 |
Gold Star Baby! Join Date: Jul 2011 Location: Warren, MI
| Re: Chinese welders
From what I know you can only weld sideways with a Chinese welder.
11-25-2014, 02:18 AM | #6 |
| Re: Chinese welders
Isn't electrode NEG. straight polarity which is what Gas less wire calls for?
11-25-2014, 08:09 PM | #7 |
| Re: Chinese welders
Welding with gasless fluxcore wire. Ground is positive, electrode is negative. Hard wire with gas is opposite. As far as my previous post I may be wrong as far as straight or reverse polarity, but yes electrode negative. Kind of confusing.
01-01-2015, 08:22 AM | #8 |
Quarry Creeper Join Date: Nov 2007 Location: Sacramento
| Re: Chinese welders
Simple multi meter should be able to give you your answer of how it is set up. Almost all of them are set for flux core wire. This might help for settings. Most of these "Chinese" welders have a 20% duty cycle, so if you have a big project it will be an exercise in frustration. |
Chinese welders - Similar Threads | ||||
welders: need help | STANG KILLA SS | Chit Chat | 37 | 07-08-2011 10:16 AM |
Any welders here? | neoakaj | Colorado | 3 | 04-21-2011 10:35 AM |
welders | punkfan | Chit Chat | 1 | 10-31-2010 01:44 PM |
need help with mig welders | flmudder | Tools, and Procedures | 21 | 06-09-2009 05:44 PM |
Welders | Shaun | Tools, and Procedures | 24 | 12-23-2007 10:08 PM |
