| | #1 |
| I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
| I picked up a scroll saw from Harbor Freight. The blades that come with it don't seem to cut 1/8" aluminum angle very well. What other blades should I be looking for specifically? It has the pinned 5" blades. I looked at Home Depot and everything they have seems to be lower tooth count specifically for wood. I'm guessing what i need is a higher tooth count (20-25 tpi)? |
| Sponsored Links | |
| | #2 |
| I joined the Band! Join Date: Sep 2006 Location: ...
| Find and buy the expensive ones |
| | #3 |
| I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
| I buy the dremel brand ones at menards for cutting aluminum. I think they are 20tpi I don't remember for shure though. |
| | #4 |
| That's about what I thought. Just have to find where I can buy them from locally. |
| | #5 |
| OG Green Meat Star Man ![]() Join Date: Nov 2005 Location: *
| i use ryobi blades on mine fine or medium i'm not too sure how many teeth per inch but the medium one works really good if you go slow, blade speed and pressure. i cut my rear shock mount from my d-trail with a scroll saw, i think that the angle alum. i used was thicker than 1/8". the blade lasts pretty long, just dont try to cut stainless or hardened and you should be okay. oh BTW let the blade catch up to where you are trying to push to,you'll see the blade flex and slow down, thats when you release pressure til it catches up. |
| | #6 |
| ... Join Date: Sep 2005 Location: USA
| I was looking at a scroll saw the other day at Lowes.....Thats some need to know info on the blades. Thanks for asking for me....lol... |
| | #7 | |
| | #8 |
| How thick of material where you cutting with the new blades? |
| | #9 | |
I just finished up with the hacksaw. I've got to replace the blade so I can finish working on some stuff today. The pack I bought had 4 or 5 in there, and it was fairly cheap (under $8 I seem to remember). | |
| | #10 |
| Rock Stacker Join Date: Nov 2006 Location: Winston Salem
| I have delta that uses plain end blades. I often use the minature hacksaw blades and coping saw blades. The mini hacksaw blades have pins and are the right length for mine so they may work for you. They are quite a bit wider like a 1/4 inch so they dont mind the thicker aluminum and cut straight really good. The coping saw blades work well too but there lower tooth count and not quite as wide maybe an 1/8th. Maybe this can help you sometime |
| Thread Tools | |
| Display Modes | |
