05-18-2015, 04:24 PM | #1 |
Rock Stacker Join Date: Apr 2014 Location: Birmingham
| Small Nut Driver Suggestions
So I had the brilliant idea of replacing all of the brass colored bolts on my SSD D-Hole wheels with black ones. While I really like the look, I've now rounded off two Wiha drivers. I really was careful and took my time but some of the bolts were really tight. Ended up using a pair of needle nose pliers and had to paint over a few scratches (and a couple of bolts that just would NOT come out). Anyway, my question is, what drivers are you guys using for these small (2mm) bolts? I have a set of Dynamite hex drivers that I really like, but the smallest nut driver I've seen from them is 4mm. Wheels Before: Wheels After: Thanks for the help! |
05-18-2015, 06:51 PM | #2 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
| Re: Small Nut Driver Suggestions
I think you can use align helicopter drivers I know they get small for there 450 size birds. Not sure if they have nut drivers though
05-19-2015, 05:54 AM | #3 |
I scoured the usual haunts & hit up Uncle Google last night but couldn't find any nut drivers, just hex drivers. Thanks for the help, but it looks like my quest continues....
05-19-2015, 07:28 AM | #5 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
LURC's tools probably aren't any better. I used up both that were sent when I put together my Adversarys. I bought a set of Wihas just to finish them. Wera is the other brand with a good rep.
05-19-2015, 12:00 PM | #6 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
Sounds like the hardware has loctite. I would get the wheels up in the oven, then try removing the bolts.
05-20-2015, 08:17 AM | #7 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Maybe use this: 2MM HEX SOCKET TOOLS |
05-20-2015, 08:21 AM | #8 |
Rock Crawler Join Date: Feb 2014 Location: ?
| Re: Small Nut Driver Suggestions Sorry to hear that but good to know ahead of time. I would have thought Cobalt was as hard as it gets for tool tips. I was considering the scale HW route but it is already a major ordeal keeping everything tight. I can't stand stripping out HW during routine maintenance.
05-20-2015, 11:15 AM | #9 |
Newbie Join Date: Apr 2009 Location: right here
I have the WIHA but I faced the end of it so that it isn't as round. Knock on wood, I haven't had any issues yet. I also had a socket from RC4wd that I epoxied on the end of a 2mm hex driver and that worked fine til I lost it... PM me if you need any help! Travis |
05-20-2015, 03:37 PM | #10 | ||
| Re: Small Nut Driver Suggestions Quote:
Wiha tools have been great too. When dealing with very small nut drivers it can be helpful to grind the end of the wrench flat (just eliminate the chamfered part of the driver socket) so that you get more engagement with the bolt head. | ||
05-20-2015, 08:12 PM | #11 | |
05-20-2015, 08:16 PM | #12 |
| Re: Small Nut Driver Suggestions Thanks for the tip. I had know idea about facing. I'm an IT guy who has only rarely had a need to use hand tools (especially tiny ones) so I feel like a kid again learning all this stuff. Thanks again for the tip. I still have both Wiha drivers so I'll have to try facing them before I buy something else.
Small Nut Driver Suggestions - Similar Threads | ||||
Losi nut driver set tip. | navyeoseabee | Tools, and Procedures | 7 | 11-25-2014 05:55 AM |
