Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: brazing
Old 01-02-2007, 07:38 PM   #1
Question brazing
i need to know what i need to braze 3/16'' brakeline and 1/8'' solid rod for a tube chassis this is my first time brazeing and i cant find anything please help
martinsimmons is offline   Reply With Quote
Old 01-02-2007, 07:47 PM   #2
you cant find anything? how many times have you been told to use the search button? there are 360 threads on the forum right now that talk about brazing. go read a few. i'll get ya started.....AGAIN.
http://www.rccrawler.com/forum/searc...earchid=522071
BigRedB2 is offline   Reply With Quote
Old 01-02-2007, 08:26 PM   #3
In the same amount of time it takes to type that response you could have said...
"harris safety silv 56%, some harris safety silv flux, and a yellow bottle of map gas"
but then again if you always tell them, they'll never learn on their own
Search some and you'll find anything and everything, I promise you.
I'm in a good mood tonight so I hope that helps
TxCruzr is offline   Reply With Quote
Old 01-02-2007, 08:49 PM   #4
Maybe I'll make a HOW TO BRAZE video. That might help some of you out.
Need to find a Camera man though. hhmm my 16 yr. old needs something to do. .
Double J is offline   Reply With Quote
Old 01-02-2007, 09:03 PM   #5
i started out answering his questions and showing him where and how i found the answers. seeing him ask all these questions that he could answer for himself ruins my good mood, :-( .
Old 01-02-2007, 10:01 PM   #6
Just like TX said. Mapp gas with a good adjustable flame torch. Not the cheap pencil torch that Lowes sells for 10 bucks. It works but barely. The rod you can either get roll or stick in Harris Safety Silv 45 or 56. The 45 is stronger since it has less silver in it. If you get the stick version you can do away with the seperate flux since it is already on the rod, but it is a lot higher. I have seen it anywhere from 3-7 bucks for one stick of 45-56. Make sure your joints are tight fitting and your tubing is CLEAN. The cleaner and tighter your joints not only will it be easier to do it will also be stronger and look better. Thats just my 2 pennys though.
maxboostbusa is offline   Reply With Quote
Old 01-03-2007, 12:16 AM   #7
There is a killer write up on the tech page. I wouldnt recommend using stick type braizing rod, it doesn't seem to flow as nice as the coil type.
xjman is offline   Reply With Quote
Old 01-03-2007, 01:00 AM   #8
thanks everybody
Old 01-07-2007, 08:58 PM   #9
Default I like this book. And it's free
http://www.handyharmancanada.com/The...ents.htm#Index
stoneym is offline   Reply With Quote
Old 01-09-2007, 10:34 PM   #10
I bet they would sell like hot cakes.
polyophio is offline   Reply With Quote
Old 03-12-2007, 02:37 AM   #11
But I can't read!! So make the video DoubleJ.
-BIGMAXX- is offline   Reply With Quote
Old 03-12-2007, 07:14 AM   #12
Hrm, I have to get mine red hot to get it to properly make the joint, but I did see this. Now I'm going to have to start on another tuber so I can practice some more. ;)
http://www.youtube.com/watch?v=62t61RZ37Bo
Cloak is offline   Reply With Quote
