02-26-2017, 03:45 PM | #1 |
Pebble Pounder Join Date: Mar 2016 Location: Mountains
| trying to solder new electronics
Ok so I got the mamba x esc and castle bec. got my kit together and am now soldering everything up but for some damn reason cant the solder to stick to the deans connection to solder the esc and bec. The f**king solder just rolls right off the deans connection. WTF !!!!! Someone help
02-26-2017, 04:03 PM | #2 |
Newbie Join Date: Sep 2014 Location: Texas
| Re: trying to solder new electronics
Make sure the connections and tip are clean mayve use some flux. Also make sure your tip is hot enough.
02-26-2017, 04:11 PM | #3 |
Hot iron and you'll need to tin the connections by holding heat to it momentarily and touching the solder to the surface of the part. It should accept the solder and be ready to stick the wore on that will also need to be tinned.
02-26-2017, 04:14 PM | #4 |
Newbie Join Date: Dec 2016 Location: Rutherford
I had that happen before. I either turned the temp up or down and tried a diff brand of solder. Def use flux though. I'm pretty sure I just used a diff brand of solder and put the temp up to 800
02-26-2017, 04:21 PM | #5 |
| Re: trying to solder new electronics Thats kinda what I was thinking. Bought a new soldering gun at wally world last night and am thinking its a pos supposed to be a 30w gun. Handle gets hot and the stem is blacking. Guess I'll go back to the pistol style I was using its old and the tip is sorta loose but it still works.
02-26-2017, 04:47 PM | #6 |
I bought a trak power station for 80 bucks and works good. If the pistol doesn't work for you. Get a station. They hold the temp a lot better
02-26-2017, 04:59 PM | #7 |
Pebble Pounder Join Date: Dec 2012 Location: Delaware
Deans need to be hot to get solder to stick to them Sent from my iPhone using Tapatalk |
02-26-2017, 05:00 PM | #8 |
Make sure the screw that holds the tip is tight. Make sure all is clean, brass brush will clean tip, tin tip touch solder to connector to tin. I always use a third hand with deans plugs 30w is a bit light for those fat wires Hang up and Drive |
02-26-2017, 05:07 PM | #9 |
are you using rosin core solder ? ( 60/40 ? ) If not, you will need use flux. That said you need to tin the tip of the iron first, then tin the deans plug prongs and then the wire ends. Then melt those together during soldering (heat) contact. A wet sponge works great for cleaning and tinning the soldering irons tips. 30 watts is kinda low IMO for tinning Deans plug prongs... tho' it should be sufficient for soldering wires. But those wires need be tinned first. 40 - 50 watts works better IMO. higher/faster heat... reduced contact time (duration) is the better way. Yer simply melting the solder together that is tinned on both sides of the connection. If using a lower wattage soldering iron... and if holding that tip on the deans plug prongs too long... it can overly heat the prongs molded into the Dean's plug housing and cause the plastic to deform (melt). So hotter works better... as you can hold it on the deans prongs for a shorter period of time to melt the solder. I use 60/40 rosin core solder wire... because using flux separately is somewhat more difficult and can be messier. But either way gets it done. My soldering station is minimally 40 watts... possibly it gets a little hotter. But it's variable so you control the wattage/heat wanted. Less inexpensive then other soldering stations and works well. Replacement tips are common place and easily obtained. I got some spare assorted tips from Radio Shack. But ebay has them for cheap as well. https://hobbyking.com/en_us/solderin...warehouse.html |
02-26-2017, 05:22 PM | #10 |
Pebble Pounder Join Date: Jun 2014 Location: North California
| Re: trying to solder new electronics This^. Always pre-tin your solder joints/tip and keep copper pad or damp cloth to clean the tip.
02-26-2017, 10:30 PM | #11 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
I use a damp cloth to clean the tip. Just be aware this will cool the tip slightly and you need to give it a few seconds to come back up to full temperature. When solder "puddles" it generally means not enough heat. As mentioned, Dean's seems to need more heat than other connectors. One trick I use is to plug the two halves of the Dean's together when soldering. The plug you're not soldering to acts as kind of a heat sink. Has worked well for me. I clamp the connector in a small hobby vise to give me the "third" hand. If the connector and wire are tinned properly it generally takes less than 5 seconds to complete the soldered connection and that's at about 750 degrees. Someone mentioned somewhere else on this forum getting a good soldered connection is just a matter of practice, practice, practice. Then, all of a sudden you've got the knack and a perfect joint! Lots of helpful advice here so good luck. |
02-27-2017, 06:34 AM | #12 | |
| Re: trying to solder new electronics Quote:
You can get the job done with a cheap soldering pen or iron, but it struggles to do the job well with thicker wire. Tinning is everything. So is getting good, thin solder with a high lead content. If you get thick solder or solder with low lead content it makes the job more difficult. I also recommend rosin core solder which "cleans" the joints at your soldering. Having stand alone flux is good as well. You either have dirty surfaces or you aren't getting them hot enough. | |
02-27-2017, 08:45 AM | #13 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
I don't think anyone else has mentioned it, but I also find it helps to scuff the tab (with sandpaper) on Dean's connectors to promote adhesion of the solder.
02-27-2017, 09:29 AM | #14 |
| Re: trying to solder new electronics |
02-27-2017, 10:21 AM | #15 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Yeah if you can tin the iron, put it on the deans connector for a second and add solder and it doesn't stick something, is off (iron iss too cold, solder sucks, ect). I used one of these guys for like 10 years and it was fine: TowerHobbies.com | Hobbico Soldering Iron 60 Watt.
02-27-2017, 03:10 PM | #16 | |
02-27-2017, 03:28 PM | #17 |
Pebble Pounder Join Date: Sep 2010 Location: Buena Park
Thought you didn't need a BEC with this esc.
02-27-2017, 07:03 PM | #18 |
Thank you all for the responses and help! I bought the solder gun at wally world ( should have known better ) The pistol grip style soldering gun I have worked like a charm. Took yalls advice and heated the plug first then hit it with solder and bam it took. didnt even take but like 15 seconds. this soldering gun is a 30-35watt. Going to be looking for a knew soldering iron real soon.
02-27-2017, 11:44 PM | #19 |
Pebble Pounder Join Date: Jan 2017 Location: Kalispell
I always use my Weller 140/100watt soldering gun for RC stuff, quick in and out. Does your gun have a way to tighten down the tip?
trying to solder new electronics - Similar Threads | ||||
Instructional video on how to solder wiring and electronics for XR 10 Switch? | Mysterious | Axial XR10 | 4 | 01-21-2013 05:48 PM |
I solder everything twice | DogSpoon | Tools, and Procedures | 18 | 07-29-2012 11:21 PM |
I Need Solder!!!! | 666 | Competitions | 3 | 06-02-2008 06:12 PM |
