03-16-2017, 02:04 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
| Cheap Shock Air Bubble Remover
Ok. Now I'm just getting way to lazy, but I've seen the air bubble remover Losi sells for like $45 and then saw somebody using a vacuum coffee saver on ebay for $12. Might have to try this as bleeding shocks takes me way too long as I'm way to anal |
03-16-2017, 08:03 PM | #2 |
Quarry Creeper Join Date: Jun 2004 Location: Melbourne Australia
| Re: Cheap Shock Air Bubble Remover
Fill'em up, push the piston up and down a few times, then leave'em sit |
03-17-2017, 08:28 AM | #3 |
never thought leaving them sitting would help. Thanks!
03-17-2017, 02:47 PM | #4 |
Pebble Pounder Join Date: Feb 2015 Location: Bay area
The best bubble remover is... gravity. Not only that, it's already in your toolbox.
03-22-2017, 07:36 AM | #5 |
| Re: Cheap Shock Air Bubble Remover Are you looking at getting these things for bladder shocks or emulsion shocks?
03-23-2017, 11:29 AM | #6 |
I'm still on the hunt for a shock that will work with linked setup for heavy rig but probably going with bladder as more rebound would probably be preferred for my setup.
03-23-2017, 12:31 PM | #7 |
I use the Tamiya RC Damper Oil Air Remover - Super Long ITEM# 54152. It's not cheap, but it really does work. https://www.tamiyausa.com/items/tool...-remover-54152 You can find it much cheaper on eBay if you wait for it to come from Asia. That's what I did. Tamiya 54152 | eBay I bet this food saver would be a cheap air remover if it's tall enough to hold shocks upright. FoodSaverŪ Quick Marinator at FoodSaver.com. |
03-23-2017, 01:24 PM | #8 |
I've been going through a lot of old junk and just tossed a vacuum pump food sealer. I think it's still in my main trash...I should pull it out and make something. The pump looks just like that Tamiya unit.
