06-20-2017, 10:41 PM | #21 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Re: New tools
They look really slick lookin .... Black handles, different color tops... Tooo cool... Can't wait to get a set
07-12-2017, 05:51 PM | #22 |
Pebble Pounder Join Date: Jun 2017 Location: United States
| Re: New tools
I wish I could have seen them, stupid photo bucket
07-12-2017, 07:26 PM | #23 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: New tools |
07-17-2017, 09:22 PM | #24 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
| Re: New tools
I purchased a set and got around to trying them. They feel really good. I like how the tips are long and they are very sharp. The cap spinning in the hand works great. I have other tools that the head spins but these one spin with precision. You can feel the screw easily threading. Example, screwing into plastic and it bottoms out. I do wish they laser etched the caps with the size like the showed in the per-production ones. |
07-18-2017, 08:08 AM | #25 |
| Re: New tools
I am interested also
07-18-2017, 04:35 PM | #26 |
| Re: New tools
Holy crap! I was like a little kid in a candy store at Harbor Freight. I "needed" the magnetic trays, I have a LandCruiser with 37" tires and each time I dig into it I always need these and I seen with the Wraith I will be needing more. Got a precision plier set, nothing fancy but will work for the little stuff, set of precision screwdrivers, hook & pick set, micro flush cutter, razor knives, watchmakers hammer and a crap load of cable ties... should have gotten a tool box but did not see a small one
07-18-2017, 05:51 PM | #27 | |
| Re: New tools Quote:
Next time your at HF, pick one of these up: https://m.harborfreight.com/toolbox-...ers-68238.html | |
07-18-2017, 06:18 PM | #28 |
| Re: New tools
Crap! I was looking at that in the store thinking it was too big. It is now... I am just starting the madness!
07-19-2017, 06:46 AM | #29 |
| Re: New tools
Ok I am a Little confused. The Hitec charger has a charge and balance feature on it and the batteries I just received had the 11.1 voltage on them but from what I read the LiPos have the full voltage until the end. The instructions I am reading says not to charge a fully charged battery. Ok, how do I know how much charge I have? Should I use the charge or the balance charge? I have 3S 2200mAh 50C batteries so the setting is 2.2 from what I understand. LiPo Charge or LiPo BALANCE 2.2A 11.1V (3S). 2.2A 11.1V (3S) With all the warnings about heat, etc. I am going to charge in the house using the LiPo approved bags I bought since it is well over 105 degrees in the garage here in Arizona. This is concerning to me since I need to be there whil charging. I feel like I am going to burn the house down! |
07-26-2017, 06:40 PM | #30 | |
07-26-2017, 07:38 PM | #31 |
| Re: New tools
Nice, you'll love it. To answer your other question about charging (this is the wrong thread to ask), always balance charge your batterys, using the balance lead on battery/charger. And the nominal/storage voltage is 11.1v (3.7v x 3) and which you should keep your battery when not using it for extended periods of time. Fully charged is 12.6v (4.2v x 3), and yes the mah of the battery is the charge rate. All batterys should be charged at 1c unless it says 2c or 3c, ect. Example, If you see a battery that shows 2c and its a 2000mah, it can be charged at 4amps. |
07-26-2017, 09:34 PM | #32 |
| Re: New tools
Thank you 84yoda, I called and talked to the tech support and they educated me! All charged and ready to go up north this weekend!
07-27-2017, 08:10 PM | #33 |
Rock Crawler Join Date: May 2013 Location: Dallas
| Re: New tools
So I got my set yesterday and immediately put them to use. Without a doubt these are some of the nicest hand tools I've ever used, period. The bearing cap spins well, however I wish they were shielded bearings rather than sealed so they spun a little easier. The handles have enough weight to spin for a while installing and removing screws. The tips themselves are beyond awesome, super sharp and a tight fit. They appear fairly hard as well but we'll see with time.
07-28-2017, 11:44 AM | #34 |
Quarry Creeper Join Date: Aug 2016 Location: Christiansburg
| Re: New tools
I ordered just the shank and 1/4 drive adapter in the 1.5mm and 2.0mm flavor Vanquish, as I use those the most. My 2.5mm and 3.0mm aren't even close to being stripped so they weren't worth replacing. I gotta say, the cuts on the tool end are beautiful!!! I'm looking forward to digging into my B1B this weekend and doing some work with these tools! |
07-28-2017, 11:51 AM | #35 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: New tools
I went similar and got the 2.0 and 2.5 tips to replace some existing pieces. I'll pick up a 1.5 tip as well, wasn't in stock when I ordered from RPP. Very nice pieces for sure. Longer than my current tips which will come in handy. |
New tools - Similar Threads | ||||
Where to get tools? | BAXTER | Newbie General | 8 | 06-24-2011 11:43 PM |
tools !!!!!!!!!! | lordjasper1988 | Losi Micro-Rock Crawler | 9 | 12-11-2010 02:20 PM |
What tools do you need? | RPP Hobby | RPP Hobby | 24 | 10-27-2008 06:40 PM |
