Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Cleaning soldering iron
Old 02-17-2007, 11:57 AM   #1
Default Cleaning soldering iron
What is the best way of going about this. The tip of my iron is all buggered up with flux. I was thinking turning it on then taking a wire brush to it? All suggestions welcome.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 02-17-2007, 11:59 AM   #2
i sanded mine before, so ya a wire brush will work too
'83 chevy is offline   Reply With Quote
Old 02-17-2007, 12:04 PM   #3
While it was on or off? I don't even know if we have a wire brush here, so I might have to use sandpaper.
Old 02-17-2007, 12:11 PM   #4
i first heated it up wiped most of it away with a rag and then sanded off the rest, and let it cool
Old 02-17-2007, 12:37 PM   #5
Ok. Thanks for the help.
Old 02-17-2007, 01:08 PM   #6
dezfan's Avatar
I just use a sanding drum and my Dremel!
dezfan is offline   Reply With Quote
Old 02-17-2007, 01:12 PM   #7
Ok. I'm getting it ready.
Old 02-17-2007, 09:48 PM   #8
yup... mine tip was damn soft though... you just have to barely hit it
JOe
Kingofthehill is offline   Reply With Quote
Old 02-17-2007, 10:06 PM   #9
Flux on your soldering iron? What are you using this iron for?
A damp sponge when the iron is hot is all that you really need. Good, old school, soldering stations come with a little spot to hold your miniature sponge.
Robb is offline   Reply With Quote
Old 02-18-2007, 12:52 PM   #10
Tronk's Avatar
Treat you iron like your willy.
Clean and wipe after every use and dont let any foreign matter build up on the tip.
Tronk is offline   Reply With Quote
Old 02-18-2007, 01:58 PM   #11
lohocla's Avatar
instead of messin around with that iron get yourself a nice microtorch. I have never looked back to an iron, unless of course your doing pcb
lohocla is offline   Reply With Quote
Old 02-18-2007, 05:41 PM   #12
That is the same advice I have given out for over 20 years of soldering...
Trikster is offline   Reply With Quote
Old 02-18-2007, 06:47 PM   #13
Yea don't you prep the tip of your iron before you use it?
I would assume wires ...
True , But maybe he does not have one.
Yes , Even the New school one do .
All I would do is sand it down till you see nice clean tip again then put a nice amount of flux on the tip , then rap the tip with the type of solder you will be useing. Then turn it on and let it absorb into the tip. The tip will be like new again .
PROTOTYPE is offline   Reply With Quote
Old 02-18-2007, 06:50 PM   #14
TLTCrawlin's Avatar
I filed mine.
TLTCrawlin is offline   Reply With Quote
Old 02-18-2007, 06:52 PM   #15
Cool, can I throw a couple of like a big man also??
Been doing electrical soldering for about 20 years now, NEVER used a single drop of flux.
Old 02-18-2007, 06:54 PM   #16
TLTCrawlin's Avatar
I dont use it. Its overrated, like fat chicks!
Old 02-18-2007, 09:56 PM   #17
I like to keep a few spare tips in my toolbox
Mad Scientist is offline   Reply With Quote
Old 02-19-2007, 07:21 PM   #18
The iron is for RC stuff. Theres flux on the tip because its stuff my mom brings home from that has the flux in it. The iron is ~20 years old and doesn't look like it ever had a proper cleaning. I do have a stand that has the little sponge, but lost the sponge. Of course theres some of you that are going be thinking, "get a new iron," well I don't need one. It works perfect for what I do, and I just wanted to clean it.
Old 02-19-2007, 07:42 PM   #19
It sounds like a Weller. If so, new tips are readily available, and might be exactly what you need.
You may only "think" it works fine right now.................a new tip may change your mind!
Old 02-27-2007, 02:27 PM   #20
hey hey now fat chicks are easy they put out quick and put out heat too
blazed is offline   Reply With Quote
