Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: stampede drive shafts to tlt axles mod?
Old 09-16-2007, 07:10 PM   #1
Default stampede drive shafts to tlt axles mod?
im putting my drive shafts in and i put the pede tranny in and i bought front and rear drive shafts and i need a pic of how to make them fit tlt axles..someone?
officerray9414 is offline   Reply With Quote
Old 09-17-2007, 07:41 AM   #2
Question
There shouldn't be an issue the shafts and yokes are a direct fit. Just cut off the the stub end on one yoke for the tranny end.
DRCMAN is offline   Reply With Quote
Old 09-17-2007, 06:36 PM   #3
He's talking about how the Tlt pinion has only one flat spot on it, while the pede shafts have 2 flat spots.
Either grind another flat spont on the pinion or take a Dremel and take away one the flats inside the yoke.
'83 chevy is offline   Reply With Quote
Old 09-17-2007, 06:39 PM   #4
I'd do a second flat spot and cross drill the TLT pinion.
Thorsteenster is offline   Reply With Quote
Old 09-19-2007, 08:22 PM   #5
drill the yoke stright through. and cross pin it on the axel
brendan h is offline   Reply With Quote
