04-26-2007, 10:50 PM | #1 |
Rock Stacker Join Date: Feb 2007 Location: Portland
| Cutting 1/4 alluminum plate?
What's the best way to cut 1/4 or 1/8 inch aluminum plate for a chassis? I have access to a ~20" band saw w/ coolant feed, a CNC mill, plasma cutter, and some air powered dremel esque thing. Which should I use to cut out a ladder style chassis? I'm leaning towards the CNC, but whats the best way to setup the plate on the table?
04-27-2007, 10:48 AM | #2 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Outside cuts - use the bandsaw Inside cuts - use the mill, unless your plasma cutter is capable of some precision work. (I've never had the pleasure of trying one, so I'm not sure how much clean-up work you'd be left with) Last edited by Big Mike; 04-27-2007 at 10:50 AM. | |
04-27-2007, 11:07 AM | #3 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Plasma doesn't usually do aluminum to nice. It is so hot is melts it to much. I agree with the other statments however.
04-27-2007, 11:35 AM | #4 | |
See post #60: El Capitan gets a face lift for Moab | |
04-27-2007, 12:08 PM | #5 | |
Pebble Pounder Join Date: Mar 2007 Location: Merritt Island
Double-sided carpet tape would make it so that it would take some force to pick it up, since you want absolutely 0 play in it. Quote: | |
04-27-2007, 05:54 PM | #6 |
thanks for the responses, I'll probably do the whole thing in the CNC.
04-27-2007, 09:25 PM | #7 |
I joined the Band! Join Date: Mar 2006 Location: Gardena,Ca.
i use a 11hp cnc router with a 20hp vaccum table, i'm just spoiled |
04-28-2007, 01:12 AM | #8 |
I think I've got you beat diaz. It a GIANT machine, made by some f-something company. I can stand up in the enclosed milling area. It's not mine, but the guy is a freind of mine and he said i can use it when he's not prototyping for adidas.
04-28-2007, 07:19 AM | #9 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
04-29-2007, 09:02 PM | #10 |
no, it's like fedor. But it is about the same size as a VMC-15800 from Fem-Tec
05-02-2007, 07:26 PM | #11 |
Pebble Pounder Join Date: Jan 2005 Location: st. louis
Fadal maybe? I have used them before, nice machines.
05-04-2007, 07:37 AM | #12 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
use the ban saw just watch your fingers please or it could mess of your throttle fingel lol just be careful
