05-31-2007, 02:48 PM | #1 |
Rock Stacker Join Date: Sep 2006 Location: Big Rapids
| Holding
Starting to work on my first tuber. What is the best way to hold things where I want them when brazing? Does anyone use jigs?
05-31-2007, 02:58 PM | #2 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
look for some welders magnets they work well or get a friend to hold the pieces while you braze
05-31-2007, 03:02 PM | #3 |
Adilynsdad too! Join Date: May 2004 Location: G ville
05-31-2007, 03:29 PM | #4 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
I use painters tape, works perfectly. Welding magnets I have found to be too heavy or not strong enough |
05-31-2007, 04:03 PM | #5 |
Ok, I was thinking of making like a clamp with some aligator clips, and a hanger. I waas thinking that way I could hold things where i need them.
05-31-2007, 05:10 PM | #6 |
Pebble Pounder Join Date: Jan 2005 Location: st. louis
go up to the rat shack and get something called handy hands the look like |
05-31-2007, 08:19 PM | #7 |
| built using nothing but painters tape to hold. Those handy hands really dont work well for me either... K.I.S.S. keep it simple stupid. |
05-31-2007, 08:35 PM | #8 |
Pebble Pounder Join Date: Mar 2007 Location: Merritt Island
I bought two cheap clamp on vices and attached them to my workbench. With a couple of welding magnets all has gone well so far.
06-01-2007, 08:59 AM | #9 |
ive found in the past that heat, removes the magnetic properties, from magnets, ie after having the torch near them and heated up, the magnets werent magnets anymore :( just paper weight, but they were ordinary "wal mart" magnets not welding magnets.
06-01-2007, 09:01 AM | #10 |
Yep, this is always something to be weary of, even if you look on the welding magnet label it mentions this. You just have to keep the magnets as far away from the flame as possible. I demagnetized many magnets when starting out because I got them too hot. |
06-01-2007, 12:07 PM | #11 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
see thats just stupid, what the he11 is the point in having a welding magnet if it loses its magnetic property when it gets hot? id say use tape. ive seen a lot of people do it that way and most of them came ou very good. and dont forget if you ae bazing if it is crooked you can just reheat it and fix.
06-01-2007, 12:13 PM | #12 | |
I just said to be weary, it isn't likely, but there is no use in demagnetizing. I haven't had any issues with the welding magnets in particular, just the magnets I had before. Quote:
06-01-2007, 02:42 PM | #13 |
Hmm, I was useing a magnet and it just split in half. So I think ill try the tape and if it dosen't work I am not out a whole lot of money. I am kind of surprised no one uses jigs.
06-01-2007, 02:58 PM | #14 | |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Read through this thread it covers a lot of issues and I posted what magnets I've been using for just about a year now and they haven't lost the strength, just the labels getting burned off them. I also have an aluminum table extension that I clamp on to my work bench to braze on that allows me to move what ever I'm working on with out the magnets sticking to them. brake line/tubing ? I tried the tape thing and hated it. | |
06-02-2007, 09:15 AM | #15 |
| For us novices it works just fine... just try a bunch of different styles, see what works best for you and go with it. Remember when building a tuber- Hot metal often looks like cold metal, stay outta the burn unit at your local hospital. |
06-02-2007, 09:23 AM | #16 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
I use a bunch of the those tiny spring clamps. They work great. I don't know how many I burned through. Also made a sandwich like clamp from two tiny pieces of wood and a bolt too hold the roof pillars on for mock up.
06-04-2007, 04:57 PM | #17 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
06-04-2007, 11:14 PM | #18 |
Pebble Pounder Join Date: Jun 2007 Location: san jose
i know this is going to sound stupid but what is brazing? is it like sodering?
06-05-2007, 06:13 AM | #19 |
It is a cross between soldering and welding that works in a temperature range of roughly 1200-1600 degrees. The bond formed when brazing is FAR stronger than anything soldering has to offer, and some people say that in some cases it is stronger than welding, though I haven't seen this first hand. Here is more on the subject: What is Brazing? |
06-05-2007, 08:23 AM | #20 | |
