09-14-2007, 08:08 PM | #1 |
Newbie Join Date: Jun 2007 Location: bdale
| Joining styrene to steel tubing
I was wondering if there is a way to join styrene to steel tubing. I tried using jb weld and super glue and neither worked. I was wonder if gorilla glue would work or any other kind of glue.
09-14-2007, 08:34 PM | #2 |
Pebble Pounder Join Date: Aug 2005 Location: Rochester
What appication is this, applying panels to a tuber?
09-14-2007, 10:35 PM | #3 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
yeah, we would need more info. if it is for panels, I usually just weld a nut onto the tube and call it a day. I cannot see a reason why you would want it permanent. I would try gorilla glue, or some type of general epoxy. |
09-14-2007, 10:37 PM | #4 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Shoe goo or goop
09-15-2007, 06:06 PM | #5 |
Yes it's for a tuber. I've brazed on nuts before but want to make a scale tuber and make it as scale as possible.
09-15-2007, 07:30 PM | #6 |
Rock Crawler Join Date: Feb 2007 Location: Ramstein Air Base Germany ...ya Ive been Ramshafted
Use some type of 2m or 3m bolt or screw that has a flat head, and appoxy them to your panels in the places you need them that way the panels will be flush on the other side with no sight of bolts or screws and you can still remove and replace the panels as necc. I wouldnt go 'perma panel' That would be bad if you need to work on the rig then you gota brake your panel to remove it. Just my oppinion though! Also use something like "Plastiweld", "Double Bubble" something 2 part mix that gets hot as its drying. Rough up the area you are going to appoxy and then wipe with alcohol to clean the area DONT USE PAINT THINNER IT MAY MELT YOUR STUFF! And I wouldnt go more than 50/50 on your appoxy mix cause to much hardener will melt plastic also becouse of the Chem used. Hope this helps! Last edited by CCFBERG; 09-16-2007 at 07:00 PM. Reason: spelling |
09-17-2007, 07:13 PM | #7 |
DONT use gorilla glue! that stuff expands like a mo fo! youll have a huge mess on your hands! |
09-17-2007, 08:33 PM | #8 |
09-25-2007, 08:54 PM | #9 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
grab drill,put in drill bit,drill hole in panel,and now add zipties.lol any pics? |
09-26-2007, 11:34 AM | #10 | |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Long story, shortened the cat killed the dog with gorilla glue If I were going to perm. attach panels I'd braze them on. and not use styrene | |
09-27-2007, 02:01 AM | #11 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
DoubleJ-almost same thing happened here with our dog:-( You can use a hot glue gun to get a pretty good but still removable effect. |
09-28-2007, 02:37 PM | #12 |
I shoo goo'd 90% of the panels on my sand rail I did the roof, hood panels, upper rear side panels, even the wing on the back is all shoo goo'd |
10-12-2007, 01:10 PM | #13 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
They have a lot of sand dunes in Suffolk County? Must have missed them last time I was up there....
