Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Small, powered driver with a chuck?
Old 11-19-2007, 12:50 AM   #1
Default Small, powered driver with a chuck?
In a post somewhere that I can no longer find for the life of me... somebody posted a picture of a small, electric screwdriver type thing. Most importantly though, instead of the typical hex chuck you usually find, this one had a little keyless chuck like a drill.
It *might* have been made by Black & Decker, but I am not sure about that...
Has anyone seen the post I am talking about? Or, does anyone know of a similar tool? I want one bad, and it's driving me nuts not being able to find it!
Thanks
TunaMaxx is offline   Reply With Quote
Old 11-19-2007, 03:52 AM   #2
Thanks
Same here. I got a little palm driver with a lithium batt. Small and works great, but hex. I'd love to find a chuck conv. or adaptor or something. If you find something, please post.
nomobux is offline   Reply With Quote
Old 11-19-2007, 10:01 AM   #3
I was searching around some more last night and found this:
It's not what I am looking for, but could certainly be used to accomplish the same thing.
Old 11-19-2007, 10:15 AM   #4
I can't see it on the card or missed it on the link. Does it just fit in any standard hex type driver, be it a screw driver type or in my case the lil palm hex driver ?
Old 11-19-2007, 10:23 AM   #5
From the description at Amazon:
1/4" Keyless Chuck converts Skil Twist, Super Twist and other 1/4" hex shank screws into a drill.
So, I have to assume it will work on any typical 1/4 hex driver.
Old 11-19-2007, 12:46 PM   #6
MWRCA'er
Mnster's Avatar
I have one of those, it has the standard 1/4 drive to fit a electric screwdriver. It works great as a keyless chuck however it cannot be spun in reverse as for whatever reason the chuck loosens that way. Electric screw drivers spin far to slow be useful as a drill.
Mnster is offline   Reply With Quote
Old 11-19-2007, 01:02 PM   #7
I don't want to use this as a drill; I already have collected more corded and cordless drills over the years than I care to admit!
What I want to be able to do is clamp the bits from my allen driver sets (with 3mm round shafts) into the chuck. That way, I can save a little wear and tear on the wrist when assembling, say... beadlocks with 96 allen bolts!
Thanks for the heads-up on not working in reverse!
Old 11-19-2007, 01:06 PM   #8
MWRCA'er
Mnster's Avatar
Then buy hex bits.
OR
Is it that they are too short?
Something like this with metric sizes.
http://www.harborfreight.com/cpi/cta...emnumber=93916
Old 11-19-2007, 01:57 PM   #9
Already have a second set of (3mm shaft) tips kicking around. Plus, after using hardened tip drivers, I don't ever want to go back to cheap, soft, quick wearing pieces again...
Old 11-19-2007, 02:03 PM   #10
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I just chuck the tips of my losi wrenches into my big cordless drill to save my wrist.
JohnRobHolmes is offline   Reply With Quote
Old 11-19-2007, 02:12 PM   #11
Location: Taylors Falls just hanging with the MNRCRC crew.
I have a Milwaukee cordless hex driver that has 2 speeds and that would be perfect for thanks
Stormin2u is offline   Reply With Quote
Old 11-19-2007, 05:22 PM   #12
Metabo Powermaxx:
Black & Decker KC360H:
Bosch IXO:
Micropuller is offline   Reply With Quote
Old 11-19-2007, 05:32 PM   #13
Could you just use some of these?
http://www3.towerhobbies.com/cgi-bin...MIP+SPEED+TIP+
It would get expensive if you needed more than one size, though.
Cubman is offline   Reply With Quote
Old 11-19-2007, 05:39 PM   #14
TEAM MODERATOR
Reflection's Avatar
WERD!
Reflection is offline   Reply With Quote
Old 11-19-2007, 05:54 PM   #15
Exactly what I do now... Just looking for something with a little less jam and easier to fling around!
I probably wouldn't be so hung up on this if I hadn't seen a post in here about it somewhere...
Originally Posted by Micropuller View Post
Metabo Powermaxx: Black & Decker KC360H: etc...
Perfect example of what I am after, except (I think) they all have hex drives. I'm after one with a keyless chuck!
Hmmm... I've never seen those. But if I bought 1.5mm, 2mm, 3mm and some standard sizes, it would probably cost as much as a whole new electric driver!
