Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: Worth the time?
Old 06-08-2008, 10:37 PM   #1
Default Worth the time?
Is building a maxx crawler worth the time? Do you have any tips on building one? Any chassis templates etc... Thank you!
paintblob is offline   Reply With Quote
Old 06-09-2008, 12:02 AM   #2
worth the time? well depends on your budget and goals for it
cherokee_guy is offline   Reply With Quote
Old 06-09-2008, 09:55 PM   #3
Have the parts but not sure what I would be getting into.
Old 06-10-2008, 05:56 PM   #4
they aren't real bad crawlers, but I don't think they will crawl as good as a clod based rig. I personally prefer a shaft driven rig, but to build a maxx based rig prepare your self for a whole bunch of hand fabrication as no one makes the parts to convert. This is the one I build over the winter, sold it in the spring and bought a scorpion
allgm1 is offline   Reply With Quote
Old 06-10-2008, 08:07 PM   #5
if you really do your research you can see the benefits of the different trucks. the basic from what i have found is the clods have super low COG and no torque twist, txt are cool because they look real, and maxx generally have high diff clearance but unfortunatally tend to have high COG. another benefit to maxx is how many different options there are to set them up. If you wanted a kit I know double J made some axle tubes at one time or you could look at how I made mine, it was pretty simple. I think axle choice should depend on what you want your truck to do.
anyway, i know you could cram alot more info into this post, but that is the condenced version.
spookyseven is offline   Reply With Quote
