11-15-2005, 10:41 PM | #1 |
Quarry Creeper Join Date: Jan 2005 Location: In the Garage!
| Project syco Started....
Ok i have started to tear my sons emaxx apart and build a better crawler out of it. I am going to custom build a chassis for it. Of course both diffs are locked. I took the front shocks off and stuck in a emaxx link to lock the front and rear suspensions. Still have to do the back. I also started on the front servo mount. I cut off the excess plastic on the front to level it out to mount a servo. Going to do the same for the rear. I am going to be running a Magnetic Mayhem on a GD600. And after talking to Twisted i will be running a 18T on the motor and a 12T or 14T on the gd 600 to the 72T spur. The tranny is not as high as it looks. the angle of the picture makes it look really high. From the very bottom of the tranny i plan on having about 5 1/4" of ground clearance. I am using that peice of brass for mock up and figure out the angles of the chassis. The chassis is going to be built out of some aluminum. it will bolt directly to the front axle, angle up to the tranny and then angle back down to the rear axle. It will be one solid piece. So with this setup the truck will have little if no flex at all. If i decide i don't like it that way i may try and put one shock back in each corner. Me, syco133 and highmark have ran our clods some with NO FLEX and it is working pretty good. Only time will tell though. OK, So let me have it. The good and the bad. thanks |
11-15-2005, 10:45 PM | #2 |
Well actually the tranny is a little high as it sits. I kept looking at it and went back out and measured it. It is sitting about with a 6 1/4" ground clearance right there. I will lower it about an 1" or so.
11-16-2005, 12:50 AM | #3 |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
I'M tellin yea it will never work Looks good so far keep us posted.
11-16-2005, 12:57 AM | #4 |
RCC Addict Join Date: May 2005 Location: the land of the midnight sun
Looks really great so far, keep that tranny as low as you can. Post up as y build it up. |
11-16-2005, 04:48 AM | #5 |
Pebble Pounder Join Date: Oct 2004 Location: P.A. just out of philly
looks nice can not wait till done
11-16-2005, 07:30 AM | #6 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
its a start is that the big Gravedigger body that you get from Walmart?? Colton has one and I thought about using that body on a gigantic project like your old hummer |
11-16-2005, 08:25 AM | #7 |
Pebble Pounder Join Date: Nov 2005 Location: Millmont
How is it going to be a crawler if there is no flex? You have the front axle lockedout so now I'm confused. I think that star of it looks cool man! Please keep posting pics so I can see some ideas.
11-16-2005, 09:33 AM | #8 | |
Newbie Join Date: Nov 2005 Location: Bracknell, UK
11-16-2005, 10:20 AM | #9 | |
Nope it is solid mounted here man.The bulkhead mounts directly to the chassy the flex will come from the chassy its self so far 4 of us around here have built no suspension trucks that work pretty dang good but this is the first shafty that is going to have it. | |
11-16-2005, 10:22 AM | #10 | |
More to come soon!!!!!! | |
11-16-2005, 01:58 PM | #11 | |
lol, sounds like a tricky way of flex'ing, be very interested to see the progression of this one | |
11-16-2005, 06:53 PM | #12 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
So are you actualy going for some flex David? Or a rigid set-up like Alf? If you're truck flexes any you're going to be doing alot of three wheeling. This is because the transmission will be attached to the back bone, and because it will be easier for the back bone to twist and the truck to tourqe roll rather than move the truck. I would HIGHLY recomend that you stick with a very rigid design or go to a 4 link. | |
11-19-2005, 08:14 PM | #13 | |
11-19-2005, 08:40 PM | #14 |
Ok i got real close to finishing the max up today. Got the chassis bent into shape. Got the front steering hooked up. I kept looking and looking on how to mount the tranny. Trying to keep it as low as possible to help with the COG. I finally decide to lay it on its side. so i mounted it up like that. It turned out great i think and works awsome. I also mounted it a little closer to the front for alittle extra weight in the front. I had the motor mounted in the bottom of the tranny but then decided to move it to the top and maybe cut off the bottom of the motor plate. I will definitely be making a skid plate. I can gain about 3/4" of an inch ground clearance. As it sits i have about 5.5" and i can get around 6" or so if i cut the bottom plate off. Got the rear links in place of the shocks. So everything is locked. I have maybe about 3" of flex. I know that sounds dumb, but it works pretty good. It is still in the developemental stages though. Well i got the front drive shaft hooked up. Tomorrow i will swing by the LHS and pick a couple of revo shafts. One for the rear and probably swap out the front one so they will match. Thing to do: Install rear drive shaft. Install rear steering just like the front. cut off bottom of motor plate and make a skid plate. Maybe? I am going to drive it as is and maybe put the motor back to the bottom and see if i can tell any difference. Oh, one last thing. Wanna know what the chassis is made out of. Check out the pics. LOL. |
11-19-2005, 08:43 PM | #15 |
more pics
11-19-2005, 10:04 PM | #16 |
very different.. but to me that is a high CoG.. specially if the motor sits up at 8 1/2"
11-19-2005, 10:23 PM | #17 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Yea...and it also looks like your going to get hung up on the drive shafts and tranny big time.
11-19-2005, 10:28 PM | #18 |
Ok, I know I'm new to R/C crawling, but please help me understand something... Your axles are locked so that they are solid axles now Your chassis is rigid (I know there will be some twist/flex) There are no shocks I don't understand how it will crawl/articulate to keep the tires down since the chassis bolts right to the diff bulkheads. I'm not trying to pick at your design at all, just not understanding it. Please explain |
11-19-2005, 10:32 PM | #19 | |
AdamF, yeah i agree. Once i figure out what i am going to do with the tranny and motor plate i will be making a long, narrow skid plate to slide on the rocks. Just trying to think outside of the bod alittle. Trying some different things. Thanks for the comments. Keep'um coming. Good or bad. | |
11-21-2005, 09:38 PM | #20 | |
Well I got my revo shafts installed and got the GD600 installed. That is a must have. 18t on the motor and a 12t to the 72t spur. Kept the wheel speed that i like but gained a lot of torque. Will be trying a 14t shortly. This thing crawled pretty good. I definitely need a skid of course. I also took off the front and rear links that locked the axles. I put one shock back on each corner. Getting that little bit of flex did a little better also. Also i have pretty much no torque twist at all. I guess it is because of the solid chassis to the axles. Since i am not using links. Needs just alittle more fabbing and it will be awsome. I will get some video this Friday at GR kicking syco133's azzzzzz. I will have my clod out there also though. More pics and video coming soon. | |
