10-23-2004, 03:29 PM | #1 |
Newbie Join Date: Oct 2004 Location: YANKTON,SD
| To much vertical seperation?
I am building an E-maxx crawler and I have roughly 3" of vertical seperation between the link mounts on the axle. Is this to much or will it be OK?
10-23-2004, 05:35 PM | #2 |
Rock Stacker Join Date: Oct 2004
| Re: To much vertical seperation?
greater verticle seperation at the axle will reduce the force on the links, however it may make the frame end mounting points interesting (if thats not a problem and the link mounts are sturdy its not to much seperation)
10-23-2004, 07:25 PM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
The downside to it is that you want your links to be parrellel to each other(looking from the side) I've got about 1 1/8"-1 1/4" at the frame.
10-24-2004, 09:14 PM | #4 |
I have about 1" at the frame right now but I have terrible rear steer. When looking at the side where should the link ends at the frame lay in relationship to each other? As I said earlier I have 1" up and down and my top link is about 1/2" closer to the axle then the bottom. Also my top links are about 3/8" longer(6" vs 6.375").
