01-29-2006, 05:56 PM | #1 |
Rock Stacker Join Date: Jul 2005 Location: port coquitlam, bc, canada
| aluminum plate SAS???
would building custom axles from something like 1/8 inch or 3/16 inch aluminum be good? im looking to jsut drill and tap the ends so the pillow balls just thread in (with lots of threadlock) so would 1/8 or 3/16 have enough material around the threads for them to not tear out? also can someone post some measurments that i can use (dont have a maxx yet.) |
01-29-2006, 06:30 PM | #2 |
Newbie Join Date: Dec 2005 Location: All over Michigan
1/8 definitely wouldn't have enough, and 3/16 would be cutting it seriously close.....I doubt that'd work either
01-29-2006, 06:49 PM | #3 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
Just use locknuts to attach the pillow balls Heres my old rig that used aluminum sheet. Maxx: Longer, Lower, Meaner |
01-29-2006, 07:28 PM | #4 |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| I did the same as custom (I got the idea from him ), and I used 1/8 6061 plate. -WRM |
01-29-2006, 10:03 PM | #5 |
Ok that makes a lot more sense....from his post I was under the impression that he just wanted to drill and tap directly into the end of the 1/8 or 3/16 plate, not bend it one more time and go through it.
01-29-2006, 10:49 PM | #6 | |
the hardest part is getting harris safety silv-56 here (small town in canada.) so what do you think is better, keeping the stock arms and locking them or doing aluminum plates? (is the extra work worth it?) | |
01-29-2006, 11:02 PM | #7 | |
-WRM | |
01-30-2006, 07:33 AM | #8 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
Aww Rich, I think a tear just came from my eye and fell onto the keyboard If you wanting to drill the ends and just tap it, 1/8" and 3/16" will not work either. The pillow ball threads are 5mm. All the axles i have done ( besides Dougs truck) was 1/4". That still barely just leaves enough to thread around, but works. Also, I serioulsy doubt that saftey silv works on Alum. very good. Plus you would rather have some type of actual metal for the axles. They do get beat up nd the alum. is very soft. It would eventually just gouge and dig into rocks. If you trying to save weight on axles though, use brakeline. Take 1/4" brakeline and use the saftey silv ( doesn't have to be 56, 45 works just fine) and braze the end of the axle shut. Then you can drill the ends out and tap them. Makes drill and tapping easier.Then use 3/16 as your side braces |
02-01-2006, 06:12 PM | #9 | |
02-01-2006, 06:36 PM | #10 |
yes that will work, but I personally like more thread to hold the pillow balls on. Plus the 5mm nut locks the pillow ball in place. but to each his own |
02-01-2006, 08:20 PM | #11 | |
