11-22-2004, 04:41 PM | #1 |
Quarry Creeper Join Date: Feb 2004
| Maxx Crawler Pic
Heres my Maxx. Its almost done Needs a Jeep Body and some more Gear Reduction. |
11-22-2004, 04:45 PM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| Re: Maxx Crawler Pic
Where are you going to put the battery? Whats your crawl ratio. I'm unsure of maxx ratios
11-22-2004, 05:13 PM | #3 |
Pebble Pounder Join Date: Jun 2004 Location: Tulsa
Where did you get the pieces that mount the shocks to the a-arms and the lockout brackets on top of the bulkheads? Thanks |
11-22-2004, 05:38 PM | #4 |
I made everything by hand .I looked at a lot of Maxx Crawler Pics and made the parts I liked. The battery will go Up front .The Gear reduction I Made .Im going to a 72spur and a 9t pinion. The Links are Arrows with 6/32 treaded rod going all the way trough .It a 16.5 wheel base. If anyone needs measure ments just ask .
11-22-2004, 05:45 PM | #5 |
Is the chassis a Rockraider or a copy? It looks slightly different. I like it though. I'm looking at final drive ratios(crawl ratios). I'm looking to keep it around 100:1 with a lathe motor. My TXT is @ 141:1 with a 27t motor and I like it. I plan on making shock mounts and servo mounts tonight.
11-22-2004, 05:56 PM | #6 |
Yup I looked at the Rockraider When I built mine.All the chassis Ive built are Aluminum side plates .On my TLT i Went more scale and it has a Frame . But... The Maxx That set up wouldnt work. Got any Pics?
11-22-2004, 05:59 PM | #7 |
Pics of what? My maxx project is named UBER MAXX. It's got a thread.
11-22-2004, 06:43 PM | #8 |
Yup ,Just Remember That.
11-22-2004, 07:00 PM | #9 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
Nice truck. looks like some good fab work there. Do you have a body yet?
11-22-2004, 07:12 PM | #10 |
Nope,Was gonna get one today Along with some Gears to play with and get it Crawling But...I Ordered some Parts For The 1:1 Jeep. In Going with either a TJ or Bronco Body.
11-22-2004, 07:17 PM | #11 |
Pic of the Gear reduction A little blury. I made it just like a GD600 But,Its all Aluminum ,and Metal gears. |
11-23-2004, 03:21 PM | #12 |
Newbie Join Date: Nov 2004 Location: Papillion, NE
Looks good What did you use for link measurements? |
11-23-2004, 04:20 PM | #13 |
Are interested in making some parts for sale?
11-23-2004, 04:57 PM | #14 |
What Parts you need? Links are 5 3/8 bottom,4 1/8 top .With out ends just the link.
11-23-2004, 05:31 PM | #15 |
I like your lock out brackets and lower shock mounts.
11-23-2004, 05:33 PM | #16 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
that gear reduction is so nice.
11-23-2004, 07:48 PM | #17 |
Thanks! When I get it dialed in I'll post how to make it.
11-23-2004, 08:06 PM | #18 | |
RCC Addict Join Date: Jun 2004 Location: SERCRC
| Re: Maxx Crawler Pic Quote:
11-23-2004, 08:21 PM | #19 |
Thanks! It took a while ,Just a Drill and some files .I'm doing to make a nother for my TLT and take of the Plastic GD600.
11-24-2004, 09:44 PM | #20 |
Have you had problems with the plastic GD or are you just going for coolness factor?
