11-29-2004, 03:21 PM | #1 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| SA Maxx revisited
Just did a few things on the maxx, like a bumper and other minor mods. Next on the list is a RockRaider chassis Went for a little crawlin today, Heres some very minor damage The rear axle was hung up on a rock, I gunned the throttle and a link popped out. Turns out the screws holding the links to the axles aren't long enough to grab onto the nylon insert in the lock nut. I'll just get some longer screws. Heres a short video from today- http://www.rcpics.net/view_single.php?medid=43893 |
11-30-2004, 05:19 PM | #2 |
| Re: SA Maxx revisited Modified LST's, taken with a brand new camera. |
11-30-2004, 05:57 PM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
Is that just all thread for your links? What size? You must drive like a chick |
11-30-2004, 06:10 PM | #4 |
Its 6-32, I've been driving hard, but haven't bent any. I usually drive on a much bigger rock pile that pictured. You'd be suprised at what 6-32 can take. I've dropped the truck a few times vertically on the front axle and not one bent link. I'll get some tube for the links eventually. |
11-30-2004, 06:14 PM | #5 |
Pebble Pounder Join Date: Aug 2004 Location: orange county n.y. , building the hydro crawler
Turn the nut around so the nylon part is threaded first that way itll stay put.
11-30-2004, 06:23 PM | #6 |
I think you drive like a sissy I'm really surprised cause you have your shocks on there too. I had my springs on 1/4" aluminum links and they were bent all over the place, and one of the broke in half. |
11-30-2004, 07:00 PM | #7 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I'm really suprised that your shocks work in that very laid down position.
12-01-2004, 03:12 PM | #8 | ||
| Re: SA Maxx revisited Quote:
12-01-2004, 03:49 PM | #9 |
Quarry Creeper Join Date: Feb 2004
I've bent solid 1/4 links ,If u use all thread and put arrow shafts over it .There real strong.
12-03-2004, 05:02 PM | #10 |
Dave, you must have jinxed me Today, I was doing some step crawling. The steps were the right length so both the front and rear tires were trying to get up a step at the same time. There was tons of wheel hop going on and I bent a link because of the torque. I gotta order some aluminum tube. Anyway, I plan on putting some grooves lengthwise in each of the LST's bigger lugs to make it act more like a Giant Trac. I also plan on lowering the body. I'll get some pictures when I finish. |
12-03-2004, 07:10 PM | #11 |
| Re: SA Maxx revisited Get it!!! Being SS would help a lot, but they still lose because they have such a small diameter. I figured it was potmetal like the allthread you get everywhere... |
12-04-2004, 12:03 PM | #12 |
| Re: SA Maxx revisited |
12-04-2004, 01:07 PM | #13 | |
12-04-2004, 11:46 PM | #14 |
Quarry Creeper Join Date: Nov 2004 Location: Canada
well if you drive like you do in that vid all the time then i see how you never bend links |
12-05-2004, 12:31 AM | #15 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Lookin better with the body lowered down all nice like-that huge boner bar look mean to Quote:
I'm guessing you don't bend many links either 8O - oh wait you don't have a video or any pics so wtf are you bitchin about another dudes driveing? | |
12-05-2004, 11:40 AM | #16 |
Yeah, I'm the carnage king, I have the right to tell everyone they drive like a ***** |
12-10-2004, 01:29 PM | #17 |
I've been bending links like crazy now. At least 3 links have been bent multiple times. I ordered some 4mm threaded rod and some aluminum tube last night. Hopefully they will hold up a lot better. FYI: 6-32 is about .140 while 4mm is about .160 |
12-10-2004, 04:17 PM | #18 |
Arrows!Youll never bend them.Just cut them to length and run the Treaded rod ,And put the ends on . Easy and Strong.
12-11-2004, 12:23 PM | #19 |
| Re: SA Maxx revisited Got the rears done. They are 1" longer for a 16.5" wheelbase. The front links will be the same length so the chassis will sit about 1/2" forward of center for more front weight. I also made the shocks more vertical but i still plan to lay them down a little more. |
