07-07-2006, 12:57 PM | #1 |
Newbie Join Date: Jul 2006 Location: Vallejo
| Newbie help with rock crawler conversion
Gentlemen, I'm new to the forum and new to rock crawling. I have read the sticky but I just wanted to make sure I understand, so I have a few questions. I would like to make my Emaxx into a rock crawler, nothing like a competitiion model, just a casual, newbie type build. Anyways my question is; A) if I get the following mods, would these parts be straight drop in modifications or will I have to do anything else. 1) 2 each # 4981X Spools 2) Hitec HS-645MG servo 3) Traxxas Spur Gear 32P 72T #4472 4) Robinson Racing 9T pinion gears # 0090 5) Integy Matrix Pro Lathe motor 55T #SCM5501 B) Do I need to get the above motor or can I just run the 2 stock titan motors that came with the Emaxx ? C) Can I still use all the MIP CVD's and center drive kit that I have installed on my Emaxx already ? D) What about anything else I might have missed ? E) If I convert the ESC to only use 1 battery, what side do you place the battery pack or is their a mod for that ? Any help would be greatly appreciated. Thanks in advance. Marcusg |
07-07-2006, 01:30 PM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
Yeah that stuff should drop right in. You can use the titans, but you'll be better off for slow controlled crawling with that 55t motor. I would say crawl with that as is and see what you like/don't like from there. |
07-07-2006, 02:20 PM | #3 |
Thanks Cloak. Do I need two of the 55t motor or just one ? Thanks again, Marcusg |
07-07-2006, 08:34 PM | #4 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
one is enough
07-08-2006, 01:12 AM | #5 | |
Newbie Join Date: Mar 2006 Location: Williamsport
Longer Wheelbase (Designing a IFS Front / Linked rear chassis to be different) Better Tires (Trying to decide between Moabs or Masher 2k's) The ability to go slower (Lathe Motor(s)) I snapped an axle shaft last weekend and am adding Revo shafts/Knuckles tomorrow. | |
