04-12-2017, 01:57 PM | #1 |
Pebble Pounder Join Date: Mar 2017 Location: Southern Maine
| Traxxas Telluride axle hex to hex width?
Does any one have the measurement from the 12mm hex to hex width? I am thinking off installing a JK wrangler hardbody with interior and opening doors on a Telluride chassis. Wheel bases close 273mm traxxas..275mm JK hardbody. I would like wheel/tire somewhat offroad but tucked in as much as possible. I would probably use 1.9's like these. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
04-13-2017, 04:37 PM | #2 |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
| Re: Traxxas Telluride axle hex to hex width?
Unfortunately, I haven't yet converted my Stampede 4x4 to a Telluride, so I can't provide the hex-to-hex width, but I can tell you the 1.9's will most likely not work. The Traxxas knuckles are very big and too close to the hex hub, so 1.9's, and even most 2.2 rims will rub against the knuckles, unless they have enough of a negative offset to keep the edge of the rim away. Then, of course, with a negative offset, your tire is even further away from the body. I did a lot of reading on various forums, and most guys had to use SCT (2.2/3.0) rims/wheels to tuck in properly. Also, the Telluride suffers a little from low ground clearance, so you'd probably want a tire with an OD of 4.5" or greater. I do believe, however, that the wheelbase will match up with those China hard body Jeeps.
04-13-2017, 04:46 PM | #3 | |
| Re: Traxxas Telluride axle hex to hex width? Quote:
Your advice(many thanks) echos my research as well...the RC4WD Gelande II probably best choice. | |
04-13-2017, 06:15 PM | #4 | |
The only reason I'm going to do a Telluride is because I already had a P4de, but also have a couple of quirky toy RC hard bodies with odd dimensions that just don't seem to fit on a regular scaler chassis, and a Telluride is still at least 10x better than the toy RC's they were removed from. | |
04-13-2017, 06:48 PM | #5 |
FYI... Telluride...GoNitro 299.99 ebay or bye direct from GoNitro 299.99 plus 5% of promo code:forever 5.
04-13-2017, 06:58 PM | #6 |
Oh, I've already got all the parts to convert my Stampede to a Telluride, plus some hop-ups. This thing will be trail-ready when I'm done.
04-15-2017, 04:21 PM | #7 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Never measured mine, but I did put some extra shallow offset SCT beadlocks from ProLine meant for the long arm SCTs on mine to narrow it up some.
05-16-2017, 07:37 PM | #8 |
Rock Stacker Join Date: Mar 2008 Location: schirever
I converted my pede to a telle suspension. You will need steering rods,shorter upper links and shorter shafts. As stated no 1.9 will fit. I used special 2.2 rpm revolver rims,they just clear knuckles in the front. Ill measure tommorow but I think hex to hex is about 8" The bandit suspension arms are 1mm narrower than the telle. Also the stock plastic steering system and plastic arms flex too much to steer large tires. Flexes too much for slow moving. |
05-16-2017, 08:20 PM | #9 |
Hex to hex with telleride arms Fully extended to max ride height with stampede shocks 8 7/8" Suspension at widest point mid travel 9" and ill researchbwhich 2.2 rim I boughts Traxxas short corse rims and tires should fit no issues Rims are Rpm revolvers 2.2 wide wheelbase model # 82232 Last edited by ou812; 05-16-2017 at 08:26 PM. |
Traxxas Telluride axle hex to hex width? - Similar Threads | ||||
swap 14 mill hex to 12 mill hex....Bully XLD Comp Axle with Knuckles Prev Next | Silvertip | RC4WD Bully | 2 | 04-26-2014 04:44 AM |
super berg width hex to hex | Rathgar | Superclass Crawlers | 2 | 07-19-2010 10:12 PM |
hex to hex width of WK axle? | STANG KILLA SS | HPI Wheely King | 2 | 08-17-2009 01:32 PM |
hex to hex width? | dieselfuel | Team Losi Comp Crawler | 2 | 07-28-2009 03:22 PM |
Hex-to-hex width | Karadjas | Axial SCX-10 | 2 | 02-09-2009 06:07 AM |
