Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: TRX4 final axle gear ratio?
Old 03-25-2018, 07:54 PM   #1
Default TRX4 final axle gear ratio?
I get confused due to the portal gears when trying to figure out the axle gear ratio. I am thinking of putting the Traxxas front Portal axle on the rear of a Axial Yeti so I can have 4WS, Portal axle, 2 speed, and diff lock. Can anyone help me out when it comes to figuring out the final gear ratio to see if is compatible with any of the Axial diff ratios? Axial diff gear ratio's are 38/13 (2.9), 36/14 (2.5), and 43/13 (3.3). Thanks a bunch!
Stan3535 is offline   Reply With Quote
Old 03-25-2018, 08:06 PM   #2
CODYBOY's Avatar
Default Re: TRX4 final axle gear ratio?
Just a little info for you. The portal gear ratio is 2.3:1 so that would reduce the stock ratio by more than 1/2. So your front axle would be dragging the rear portal all over. About the only way you could make it work would be to use a transfer case with gearing that add that 2.3:1 back to the rear drive ratio. I don't think what you want to do would work very well. JMO
Ernie
Here is a chart of numbers I crunched when building my ascender portal axles. The final numbers may not work for you but the formula would.
CODYBOY is offline   Reply With Quote
Old 03-26-2018, 08:56 AM   #3
Thanks Ernie. I saved that chart
Old 03-28-2018, 08:23 AM   #4
Great Work
Thanks
OldNASCARCrawler is offline   Reply With Quote
Old 08-10-2018, 11:01 PM   #5
I think your numbers are off, Diff gears are 34/11 or 3.09/1
Gear Options:
Underdrive: TRA8288
Standard: TRA8279R <--------this one
Overdrive: TRA8287
(edit) maybe those aren't the dif gears, TRA8282 are dif gears but look different they are 18/11 or 1.38/1
and the portal gears look like 23/10 or 2.3/1 TRA8258 and TRA8257
I cant count the teeth in the picture might be 23/9 which would make the whole axle 7.9/1
I'm just looking at the parts at a online hobby store and counting teeth. not owning a trx4 to see which gears go where.
I think the total axle reduction (front, don't know if rear is different) is 2.3*3.09=7.11
(numbers are rounded)
my calculations for the transmission are also
1st gear 36/18 or 2:1
2nd gear 24/30 or 0.8:1
to calculate your final gear rato
main * trans * diff * portal
1st gear = (spur/pinion)*(36/18)*(34/11)*(23/9)
ex stock = (45/11) * 2 * 3.09 * 2.56 = 64.72
easiest1 = (45/11)*15.8=64.63 first gear
2nd gear= (spur/pinion)*(24/30)*(34/11)*(23/9)
easiest2 = (45/11)*6.32=25.85 second gear
So if you wanted you could probably get a 9T 48P pinon and 68T 48P spur and have 119.36/1 first gear and 47.75/1 second gear reduction.
I don't know if this spur is available, if it is it probably dosen't say trx4 on the package. But it looks like a fairly basic spur to me.
Voodoobrew is offline   Reply With Quote
Old 08-26-2018, 05:02 PM   #6
I miss read this, but how did you intend to mount the Traxxas portal axles to a axial Diff? oh, you mean match it to the front diff...
nevermind, Im slow
Old 09-30-2018, 08:35 PM   #7
I know this is an older post but how hard would it be to put a set of trx portal axles on a scx10 ii? And would the gearing be so low that it would be useless? Thanks for any help.
4kids crawlin is offline   Reply With Quote
Old 11-18-2018, 06:23 PM   #8
I did this but have a gcm scale transmission so my initial transmission output ratio is slightly different thanthe 10.2 kit trans. Top speed on a 1900kv brushless 3s is about walking pace though. Putting the axles underneath required custom length links pretty much all around.
I was thinking of putting a trx axle on the front of a toyzuki v2 with an OD gear set, leaving the AR44 I have on it in the rear. Haven't run the numbers but I'm hopeful the OD gears and transfer case OD will overcome the difference between front to rear. Maybe even still have a little OD upfront, this thread should help a lot.
Sent from my SM-G950U using Tapatalk
Jeepy84 is offline   Reply With Quote
Old 11-18-2018, 06:52 PM   #9
After crunching numbers, nope. Gonna have to lose the rear leaf AR44s and put the other trx axle back there on links. Final ratio difference front to rear is 1.67. Unless I run a secondary reduction to the rear axle, which is probably doable, but hard to justify, given the space I would have to work it into.
TRX4 final axle gear ratio? - Similar Threads
Axle Gear Ratio TruckBasher Tamiya Txt-1 and Juggernaut 9 04-11-2011 11:13 AM
Final Gear Ratio SeanD HPI Wheely King 3 03-03-2008 01:18 PM
whats your final gear ratio? Calderwood General Crawlers 7 07-05-2007 06:49 PM
96,62:1 final gear ratio Rikpal Tamiya Clod Buster 2 07-08-2006 11:56 AM
final drive ratio and maxx diff ratio? mike5721947 Traxxas Crawlers 4 07-10-2005 01:58 AM
