Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: trx4 pro scale light question.
Old 09-02-2021, 07:38 PM   #1
Default trx4 pro scale light question.
Hey everyone, getting back into R/C trucks since I was a teenager and I to R/C crawling. I bought a trx4 bronco since I had a bronco when as my first truck. One of the first mods I did was lighting and went with the Traxxas pro scale since it was plug and play till I get my Witt's about me. Everything went well except the rear brake and turn signals don't work in any function or mode. I have the grey jumper installed in terminal f and the tail lights in terminal c. I just wanted to know if it was normal for this kit or I missed something. Thanks for the help.
ThatGuy8820 is offline   Reply With Quote
Old 09-24-2021, 04:39 PM   #2
Default Re: trx4 pro scale light question.
Double check the esc mode you're in... Trail, race, etc... Some mode's like "Crawler" mode don't activate the brake lights
Seanygreen is offline   Reply With Quote
Old 10-12-2021, 05:36 AM   #3
I had the same issue and called traxxas. The pro kit needs both light modules 8032 and 8036 for the Bronco. I am missing 8032 which is the reverse lights. I was told that will fix the issues.
I have the TQI controller with blue tooth. The app has a bunch of functionality built in for the lights on the pro kit. I am still figuring it out. I added rock lights too. Plug them into slot 7 on the power module.
I hope that helps
Gomolajoe is offline   Reply With Quote
trx4 pro scale light question. - Similar Threads
TRX4 Bronco Light kit aiwaloki Traxxas TRX-4 5 02-27-2021 02:48 PM
TRX4 light kit install smc-93 Traxxas TRX-4 2 11-22-2019 03:11 AM
TRX4 light kit help skybolt Electronics 2 10-24-2018 04:41 AM
