02-12-2022, 02:49 PM | #1 |
Newbie Join Date: Feb 2022 Location: Beverly Hills
| AgFRC 40Kg servo on Defender?
Hi, I'm new to this rc crawling hobby, being more familiar with rc heli crashing. In fact I'm so new to crawling I haven't even ordered my trx4 defender yet. So in researching I see that the servo is a definite weak link, and was thinking of replacing with a AGFRC 40kg unit. Is this a good or bad choice? Future crawling performance mods would include motor and ESC. In considering these future mods, what would pair up well with the 40kg servo? If it makes a difference I live in hot Floriduh. I was looking at the Hobby wing and Castle line, and of course open to any and all suggestions, Thanks.
02-12-2022, 05:59 PM | #2 |
Quarry Creeper Join Date: Nov 2020 Location: Greece
| Re: AgFRC 40Kg servo on Defender?
Hi. I'm not familiar with that particular servo, but you should check the specs for the Amperage required. Stock ESC only delivers 1Amp which is way too low for any aftermarket servo. You might need a BEC to gp with it. Or you could get a Hobbywing 1080 WP ESC that comes with a decent internal BEC and cost around the same as getting a proper BEC. But my advise to you would be to get the truck first, drive it around your area to get to know it in stock form. Then you can make an educated decision on what needs to be changed/upgraded. Stock electronics are not great, but are not rubbish either. They can take you some way, until you decide what you really want for your truck. Don't fall in the ''money spending'' hole, without even trying the truck. There's plenty of time for that later |
02-12-2022, 11:54 PM | #3 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
xagoras is right, that servo looks pretty good but needs 5 amps of current.
02-13-2022, 12:38 PM | #4 |
Pebble Pounder Join Date: Oct 2018 Location: boise
AGFrc is a great brand and in fact is the OEM for many companies such as reefs, ndrsc ect. That being said check out some of their direct powered versions. That would allow you to use your stock esc.
02-14-2022, 01:07 PM | #5 |
Quarry Creeper Join Date: Dec 2019 Location: California
A hobbywing 1080 ESC is around 40 dollars, and that has strong enough of a BEC to supply the correct amount of amperage to that servo. It also gives a lot more programming options for crawling.
AgFRC 40Kg servo on Defender? - Similar Threads | ||||
AGFrc A73CHLW | themountain | Electronics | 0 | 06-08-2020 05:00 AM |
Custom Defender & Defender Gelande 2 | RCtouring | Scale Videos! | 0 | 05-19-2016 06:09 AM |
defender 110 of rcmodelex and defender 90 of rc4wd on the rails | gionata78 | Scale Videos! | 2 | 04-15-2013 05:00 PM |
Turnigy HV-300 Digital HV-3S Servo 38.40kg/ .130sec / 79g | losikid | Electronics | 5 | 08-12-2010 04:53 PM |
Defender nededs help with servo choice | Edward531 | Tamiya TLT Crawlers | 5 | 04-17-2007 08:00 AM |
