12-10-2022, 12:22 PM | #1 |
Newbie Join Date: Dec 2022 Location: US
| Upgrade servo
Just got the our first RC. Got the 21 bronco and was thinking about upgrading the servo to the RS800 V2*is this a plug and play or what else is necessary? Sent from my Pixel 6 Pro using Tapatalk |
12-10-2022, 03:56 PM | #2 |
| Re: Upgrade servo
if that is a direct power servo your gona need a sorce for power if you dont already have a sorce for power than you can ether solder in a power port /jst plug to the battery plug on the esc side or buy a adaptor that has jst plugs built in to it |
12-10-2022, 04:02 PM | #3 |
| Re: Upgrade servo
something like this would make it vary easy https://www.ebay.com/itm/12499005322...mis&media=COPY |
12-10-2022, 04:09 PM | #4 | |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: Upgrade servo Quote:
All you need is the cheaper 35kg servos off Amazon. Sent from my SM-S906U using Tapatalk | |
12-10-2022, 06:39 PM | #5 | |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
If I’m not mistaken the stock Esc has a separate (red, two-wire) JST plug from the factory. The RS800 should connect to that, and to the stock ch1 port (which I think there are two ch1’s, can go into either) in the receiver. Should be fairly straight forward install. Be advised that any servo needs to be centered before installing the servo horn, and end point adjustment is crucial to prevent damage to the steering/suspension, or the servo itself. That is a pretty powerful servo, so you do run the risk of breaking parts if you have an aggressive driving style. In my experience, more powerful servos will cause some significant flex at the chassis side panhard mount. I can also vouch for the $25 ds3235 servos to be a noticeable upgrade from stock. Sent from my iPhone using Tapatalk | |
12-10-2022, 08:15 PM | #6 |
Rock Crawler Join Date: Aug 2005 Location: Augusta
| Re: Upgrade servo |
01-06-2023, 06:37 PM | #7 | |
Newbie Join Date: Dec 2021 Location: US
01-07-2023, 02:50 AM | #8 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: Upgrade servo |
01-07-2023, 06:02 PM | #9 |
Pebble Pounder Join Date: Aug 2020
| Re: Upgrade servo
I started off with a 20$ ds3218 20kg on my first barely upgraded scx 10.2 and could bend the steering linkage with it. I’ve upgraded the steering linkage and thought about going to a reefs 444 or Holmes shv500 but honestly I’m still happy with the ds3218 even with the rig heavily upgraded now. Sent from my iPhone using Tapatalk |
Upgrade servo - Similar Threads | ||||
Servo upgrade | mud4x4lover | Axial AX10 2nd-gen | 12 | 12-07-2018 07:02 AM |
I need a servo upgrade | Shilow | Electronics | 10 | 12-24-2014 09:01 PM |
Servo Upgrade | curious crawler | Redcat Crawlers | 2 | 02-06-2014 05:22 PM |
Best servo upgrade | Billmoore1 | Electronics | 2 | 11-01-2012 03:17 PM |
servo upgrade? | evil_monkey | Redcat Crawlers | 11 | 08-19-2012 09:49 PM |
