Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: flex shafts
Old 05-29-2007, 02:19 PM   #1
Default flex shafts
i have been thinking on buying an rc boat for awhile and while looking i saw some boate that had a flexible dive shaft alot like the speeddometer on your car
do you think these would work
you could still technically have a shafty but it would give you more ground clearance
tell me what you all think
kacz7895 is offline   Reply With Quote
Old 05-29-2007, 02:39 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
I personally do not think they would work. When you would get into a bind or stress the driveline, they would tend to just wind up into a ball and just twist into a pretzel and not apply the force to the rear end.
TwistedCreations is offline   Reply With Quote
Old 05-29-2007, 02:45 PM   #3
yeah i think if the cable shaft was big enough to the point it wouldnt wind up, then it wouldnt flex either with the pressures on it.
Thorsteenster is offline   Reply With Quote
Old 05-29-2007, 02:53 PM   #4
i suppose it would be like a spring when under pressure.. you get nout for a few secs then bam all thet power in a tiny litle burst.
theshimonator is offline   Reply With Quote
Old 05-29-2007, 03:01 PM   #5
jeepster26104's Avatar
I would say that it would work in one direction and not the other.
jeepster26104 is offline   Reply With Quote
Old 05-29-2007, 06:54 PM   #6
toy4crawlin's Avatar
I'm not familiar with boat flex shafts
But I think the Flex shaft they sell for Drills so you can screw a screw in a hard to reach corner or those flex shafts they sell that attach to your 1/4 ratchet then those would be plenty strong and are equiped with a universal already !
I bought one last month, about $7. at 4-5" long.
Connect universal at other end and adapt to your shaft
or I'm sure you could weld a joint on there
humm
I'll take a picture tonight and post it
toy4crawlin is offline   Reply With Quote
Old 05-30-2007, 06:47 AM   #7
thanks for the input
i can understand what you all were thinking about it twisting but couldnt you zip tie it to something to prevent this
also thought about using them to make axles instead of dog bones
i really need to build my own rig to test these ideas out
Old 05-30-2007, 10:00 AM   #8
No way these will bind or bend up
found at local hardware store
fits 1/4
Hope this helps ya
Old 05-30-2007, 03:07 PM   #9
the ones on the rc boats had a casing around them but those would work too
Old 05-30-2007, 03:07 PM   #10
there not exactltly flexibl though.... those are more bendy than flexible.
