05-29-2007, 02:19 PM | #1 |
Newbie Join Date: Apr 2007 Location: hopkinsville
| flex shafts
i have been thinking on buying an rc boat for awhile and while looking i saw some boate that had a flexible dive shaft alot like the speeddometer on your car do you think these would work you could still technically have a shafty but it would give you more ground clearance tell me what you all think |
05-29-2007, 02:39 PM | #2 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
I personally do not think they would work. When you would get into a bind or stress the driveline, they would tend to just wind up into a ball and just twist into a pretzel and not apply the force to the rear end.
05-29-2007, 02:45 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
yeah i think if the cable shaft was big enough to the point it wouldnt wind up, then it wouldnt flex either with the pressures on it.
05-29-2007, 02:53 PM | #4 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
i suppose it would be like a spring when under pressure.. you get nout for a few secs then bam all thet power in a tiny litle burst.
05-29-2007, 03:01 PM | #5 |
Quarry Creeper Join Date: Jun 2004 Location: Boaz
I would say that it would work in one direction and not the other.
05-29-2007, 06:54 PM | #6 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
I'm not familiar with boat flex shafts But I think the Flex shaft they sell for Drills so you can screw a screw in a hard to reach corner or those flex shafts they sell that attach to your 1/4 ratchet then those would be plenty strong and are equiped with a universal already ! I bought one last month, about $7. at 4-5" long. Connect universal at other end and adapt to your shaft or I'm sure you could weld a joint on there humm I'll take a picture tonight and post it Last edited by toy4crawlin; 05-29-2007 at 07:08 PM. |
05-30-2007, 06:47 AM | #7 |
thanks for the input i can understand what you all were thinking about it twisting but couldnt you zip tie it to something to prevent this also thought about using them to make axles instead of dog bones i really need to build my own rig to test these ideas out |
05-30-2007, 10:00 AM | #8 |
No way these will bind or bend up found at local hardware store fits 1/4 Hope this helps ya |
05-30-2007, 03:07 PM | #9 |
the ones on the rc boats had a casing around them but those would work too
05-30-2007, 03:07 PM | #10 |
there not exactltly flexibl though.... those are more bendy than flexible.
