05-24-2007, 02:26 PM | #1 |
Rock Stacker Join Date: Apr 2004 Location: Bamberg / Germany
| E-Maxx Stick-Crawler |
05-24-2007, 06:12 PM | #2 |
Pebble Pounder Join Date: Sep 2006 Location: hamilton
looks pretty good for a start
05-24-2007, 07:42 PM | #3 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
looks nice i would like to see how this goes
05-24-2007, 08:25 PM | #4 |
Pebble Pounder Join Date: Feb 2007 Location: sunman
wooow 19.5 wb is crazy, what you running jumbo kongs?
05-26-2007, 04:28 AM | #5 |
Thanks guys! Hmmm, I have the Jumbo Kongs but they are reserved for another project. The Maxx will have the black cutted wheels for first. Perhaps IŽll try some 40-sized tyres later... And no updates on this long weekend --> party at a friendŽs home with lots of meat (barbecue grill) and alcohol... Manuel |
05-30-2007, 07:30 AM | #6 |
Rock Stacker Join Date: Jun 2006 Location: Norway
Thats big.
05-30-2007, 07:41 AM | #7 |
Rock Stacker Join Date: Mar 2007 Location: Romeo
looks good, but i think you are going to have a hell of a time getting the revo shafts to extend out so far without leaving them room to not slip. if there is about a 1/4 inch in to the female shaft, they will start to slip under load. good luck |
05-30-2007, 08:01 AM | #8 | |
Or in other words: This will be a layout with independent motors... ;) IŽm working on 3 projects right now so updates will follow these days... ...later... ...or so... Manuel | |
05-30-2007, 11:04 AM | #9 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
I did notice that the pinion shafts were on top. Are you going to make this a top loader. I have thought about doing this before with some worm gears for added reduction and self braking. I have also thought about using a small planetary gearbox at each of the wheel hubs for reduction. The full sized monster trucks use this method to keep from breaking axles. |
05-30-2007, 11:25 AM | #10 |
IŽll use a 1:50 reduction gearbox each axle, that should give enough power and smoothness for crawling. Disadvatage is the the mounting of that thing to provide the advatages of the stick-chassis... Manuel |
05-30-2007, 09:41 PM | #11 |
Quarry Creeper Join Date: Aug 2006 Location: olympia
I am really curious to see how you get the motor mounted...
05-31-2007, 09:54 PM | #12 |
Another idea that I've had was to keep the pinion shaft horizontal like it normally is and afix a gearbox to the pinion shaft. The gearbox goes up to where the motor is attached above the center section. The motor sits parallel to the pinon shaft. The Heim joint is then attached to the top of the gearbox giving you a good amount of ground clearance. The only problem with the worm gear top loader idea is that the input shaft and drive shafts will be off center compared to the Stick. The only other way to use the worm gear idea is to build an axle from scratch where the worm gear arrangement takes the place of the differential. |
06-10-2007, 03:53 AM | #13 |
Hi! Finally some new pics: ;) Click pic 4 gallery! But I got to rebuild it. The chassis is too loose and the servos can clearly move in their monts under loading. So whatŽs the deal? IŽm planning to strip it down to the naked axles and restart at point zero. Perhaps IŽll try the stick again, perhaps IŽll do something different - thereŽs at last a complete tranny from the E-Maxx that is gettin bored... IŽll keep you updated... ;) Manuel |
06-10-2007, 04:30 AM | #14 |
Rock Stacker Join Date: Jan 2007 Location: Queensland
That motor setup is hella sweet man!! Sounds big to, nothing better than a super rig!!
06-10-2007, 05:35 AM | #15 |
Thanks! That geared motors (1:50) are impressive and very powerful. At 6V they deliver an axle-breaking 400 N/cm (don´t know the conversion for the american measures)! And I´m using 14,4V... Manuel |
06-17-2007, 12:31 PM | #16 |
any updates on this rig? I've seen a couple other maxxes like this with stampeded trannys mounted on each axle on the skidplates and heared it was a go anywhere machine? Hows your setup?
