06-27-2007, 07:07 PM | #1 |
Newbie Join Date: Apr 2007 Location: Montreal
| REVO crawler!!!
Here's my revo crawler! axles: revo, locked with plates of plexi glass links: revo and maxx turnbuckles driveshafts: heavilly modified revo center driveshafts hardware: HEX SOCKET HEAD servo: 1/4 scale monster! motor & gearbox: from a 14v drill, planetary reduction, metal gears chassis: cutting board and tlt TVPs battery: gp3300s electronics: speed control from drill, controlled by servo diffs: locked with epoxy tires: lst pics!!! http://picasaweb.google.co.uk/jimboinue/MyDocuments please tell me what you think...thx! |
06-27-2007, 07:11 PM | #2 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
very nice man hows the cog? it looks a little high?
06-27-2007, 11:03 PM | #3 |
Quarry Creeper Join Date: Nov 2006 Location: Reno
wow! Thats sweet!!
06-27-2007, 11:18 PM | #4 |
Rock Stacker Join Date: Jun 2007 Location: my mom's basement
looks sweet. But one question, don't rockcrawlers do better with a solid axle? Wondering how that independent setup will do. What do I know though I'm a noob. |
06-28-2007, 03:31 AM | #5 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
thanks for the virus and popups don't try to enlarge any of the pics! but looks good of what i saw! |
06-28-2007, 10:02 AM | #6 | |
Rock Crawler Join Date: Jun 2006 Location: Sinking Spring
Actually in the pics he has the axles locked out so they work as a solid axle. The only thing that you might want to change is the shock mounts. Try making the shocks just bolt right onto the axles. It will make it sit lower and give you a better center of gravity. Otherwise it looks really good. Krystopher | |
06-28-2007, 01:02 PM | #7 |
Quarry Creeper Join Date: Feb 2007 Location: East Aurora
looks good, all i would do is make it so the outside links conect toe the a-arms for a beter stance and it would eliminate torque twist and i wuold also move the shocks to the axles so it sits lower but other then that it looks nice...oh and move the servo on to its side, it just seems alittle unecesary to have it sitting so strait up!!
06-28-2007, 08:32 PM | #8 |
wow, thanks for all the comments! about moving the shocks so that the chassis sits lower, i dont really want to compromise my belly clearance, right now its 6.5" and I'm really happy with that I might make a plate so that I can attach the shocks to the axles... any other suggestions to lower cog??? (other than the obvious) also, I have to retriangulate the links cause if you look closely you can see they're slightly off thanks |
06-28-2007, 08:39 PM | #9 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
It is a fine line. Too much CG vs too much center clearance. | |
06-30-2007, 10:25 AM | #10 |
any more comments?!?!?! anyone like my use of a drill motor and gearbox?? and im pretty sure mine's the first revo based crawler (as far as I could find on the boards) |
