06-29-2007, 08:16 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: portland
| mounting an emaxx tranny to a tuber
hey guys. i am planning on running a tuber chassis with a flat aluminum belly. i want the best performance i can get out of it, so i want to mount my tranny with the motor as low as possible. that means i will mount it sideways. but im confused on how to bolt it to the chassis. should i just use the stock mounts and bolt them to the side of the chassis? or will that not be strong enough? any suggestions would be greatly appreciated thanks
06-29-2007, 08:20 PM | #2 |
follow up. i see that most everyone just mounts them normally. is that because the tranny is heavier than the engine? would that be the best way to do it?
06-30-2007, 05:22 AM | #3 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
06-30-2007, 03:20 PM | #4 |
yeah i seen that. there are a couple more that are mounted sideways. but the majority mounts them normally. i take it that you believe that mounting it sideways is the best way? not that i don't believe you. i just want a few more opinions. it seems weird to me that everyone says mount the tranny with the motor at its lowest point, but almost everyone just mounts it normally. mostly i have heard the "motor at the lowest point" theory with people who run "pede" trannys. because the motor out weighs the tranny. but im not sure if that is the case with a maxx tranny. |
07-02-2007, 06:55 PM | #5 |
Pebble Pounder Join Date: Feb 2007 Location: sunman
It doesnt matter if the tranny outweights the motor, you still want the motor as low as possible, twistedcreations actually used a tmaxx tranny there i belive, same as i did, get that motor as low as possible, the tranny will follow the motor where ever it goes and wont effect your cog as long as the motor is low.
07-08-2007, 09:26 PM | #6 | |
