07-23-2007, 04:02 AM | #1 |
Rock Crawler Join Date: Apr 2007 Location: portland
| has anyone ever done this?
i was thinking about an e-maxx tranny set up where the tranny is mounted sideways ( with the motor turned parallel to the axles) and using a e-maxx diff as a transfer case. this way the motor torque is pushing down on the front. anyone ever done that? if not, does it sound like a good idea?
07-23-2007, 04:14 AM | #2 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
hey there I am not sure if anyone has doen it but the torques twist is generated allong the drive shafts that connect the diffs to the transfercase, tranny. The way to eliminate torque twist on an maxx setup is to have the driveshafts (propeller Shaft) enter the diff from the top or to put a reverse in line with one of the driveshafts and turning that diff, so that it spins opposite of the other diff. |
07-23-2007, 12:09 PM | #3 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
it was tried once before about 1 1/2 yrs ago or so. The point was for gear reduction if I remember right and the project was abandoned. Eitehr way it wont kill the twist. Best way to eliminate torque twist is with a properly laid out suspension.
07-23-2007, 03:43 PM | #4 |
im not trying to get rid of torque twist. i don't have any. i have a good suspention setup. i know that torque twist comes from your driveshafts turning and no matter how you mount your tranny, without proper suspention settings it will twist. what i was thinking about is mounting the tranny sideways so the motor torque pushes down on the front for better front traction on steep terrain. and was wondering if the torque generated by the motor turning is great enough to push down on the front and provide better front traction. |
07-23-2007, 04:14 PM | #5 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
nope.
07-23-2007, 04:18 PM | #6 |
07-23-2007, 09:14 PM | #7 |
Quarry Creeper Join Date: Nov 2006 Location: land of make believe
actually in a recent article in radio control car action they are talking about the same thing. the "King of Crushers" article with the txt....the guy mounted his motors transverse to accomplish what you are talking about....Straight from the article: I mounted mine perpindicular to the truck's centerline instead of parallel so that the motors' torque loads the suspension from front to rear instead of side to side. To compensate for rear suspension sag under acceleration, I positioned the transmission so that the motors' torque actually pushes the front suspension down to give the tires more traction.... Grapegoat, i wouldnt be so quick to dismiss this idea...you might be on to something... |
07-23-2007, 10:17 PM | #8 | |
Im gonna do it. thanks man. Now i just need a e-maxx diff. im probly gonna get a aluminum one from i think Integy and put a spool in it. that would be the strongest way to go. im gonna mount it like it is mounted in the axle using custom side plates with the dye holes drilled in and re-enforce it with plenty of crossmembers made from nuts and bolts. should be pretty sweet. it might not push down on the front a whole bunch but it will make a difference. Atleast its a project and something you don't see everyday | |
07-24-2007, 07:36 AM | #9 |
that is gonna be fun to build. not only will it put added torque weight on the front but using a e-maxx diff as a transfer case and using a 72t spur and 9t pinion, i will be rockin 180:1 crawl ratio. no more need for a gd-600 |
07-24-2007, 11:34 AM | #10 |
Newbie Join Date: Dec 2006 Location: UK
How bizzare, I had the same kind of idea a few years back when I had problems with my TXT twisting over to one side from BL power (racer), but I didnt know the torque came from the shafts, rather than the motors/tranny. Never got anywhere with it, just stiffened up the suspension & lowered it. I look forward to build pics!
07-24-2007, 11:55 AM | #11 |
i have thought a little bit about this. there is one way it would work effectively...the diff couldn't be integrated with the chassis. if it were, the torque of the motor wouldnt be translated to the chassis. so the diff needs to be relative to the axles somehow and there lies your problem.
07-24-2007, 02:28 PM | #12 | |
07-24-2007, 02:31 PM | #13 | |
07-24-2007, 10:59 PM | #14 | |
Pebble Pounder Join Date: Jun 2007 Location: My House
If you're dead set on testing this though, first build the truck without the new diff, just the traditional tranny and find something that you can't quite crawl up. Then to the mod and add the new diff, but keep the suspension geometry and static weight balance the exact same, then go see if you can make it up the thing you couldn't before. That will tell you if doing this was beneficial at all. | |
07-25-2007, 01:04 AM | #15 |
oh. i think i see what you guys are saying now. yeah your right. it wouldn't really work as planned. and if after stressing the mounts any of the left over torque that would go to the front of the chassis, wouldn't be anything noticable. its not worth the work. damn! i thought i came up with a killer idea that would take my maxx to new capabilities. if there was just a way to transfer that torque to the front. i almost still want to try it, but im lazy. i only want to do it if i know it would be a good improvement. what about that guy in rc car action mag. with his txt. he did it. sounded like it worked for him. hell, im just gonna have to do it and find out.
07-25-2007, 01:11 AM | #16 |
no. your right. it wont work. it will just try to twist my mounts. it just clicked, the ducks fell in line, i totally understand now. thanks guys, you just saved me from hours of pointless tinkering. |
