Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Truck Bed Body Mod
Old 08-09-2017, 10:01 PM   #1
Default Truck Bed Body Mod
I jumped on the Truck Bed Mod but may keep the cage intact, just not sure about the adding the roof rack back and just use the bed to help LCG
djmaincheese is offline   Reply With Quote
Old 08-10-2017, 01:46 AM   #2
Default Re: Truck Bed Body Mod
I love the look with the rack and cage all intact. Very clean job
rockhugger is offline   Reply With Quote
Old 08-10-2017, 06:48 AM   #3
Second the notion. From pictures this looks like how it came out of the box!
AggressorBLUE is offline   Reply With Quote
Old 08-10-2017, 06:57 AM   #4
I 3rd the notion, looks factory, very clean job!
fomoco is offline   Reply With Quote
Old 08-10-2017, 10:40 AM   #5
That may very well be the cleanest conversion yet. Please tell us you have a step-by-step install of this process!
RCTom is offline   Reply With Quote
Old 08-10-2017, 05:50 PM   #6
Love this mod. I am sorely tempted but am not sure how I could finish the bed. You could even remove the inner fenders and brace and sink the ute bed down a bit for tools and an esky or even some militia blokes with AK-47's lol!
CoolRunning is offline   Reply With Quote
Old 08-10-2017, 05:55 PM   #7
Very nicely done DJMC! I'm pretty confident I'd be able to do this mod to my trx-4. What I'm not confident in is getting the cuts to the body as straight and clean as this was done. Strictly speaking for myself lol
...and this...
CR4NK is offline   Reply With Quote
Old 08-10-2017, 10:16 PM   #8
Just use blue painters tape as a guide and a new thin cut dremel disc. You will be surprised how easy it is.
Old 08-11-2017, 01:58 AM   #9
Who makes those suspension links? I just like that you can see them the traxxas ones are black
Mountainsofbeer is offline   Reply With Quote
Old 08-11-2017, 05:11 AM   #10
looks like the brass links from mfr.
https://metalfabbyreed.com/collectio...products/trx-4
magic_yeti is offline   Reply With Quote
Old 08-11-2017, 06:08 AM   #11
Moderator
JatoTheRipper's Avatar
That looks great!
Old 08-11-2017, 06:30 AM   #12
Agreed! I'm seriously thinking of making this change to my rig. Makes it look less boxy, plus gives me bed space for accessories.
jebster is offline   Reply With Quote
Old 08-12-2017, 05:25 PM   #13
I just had to do the truck bed mod also, just posted a pic of it , on mine I kept the roof an used it for the bed cover
Old 08-12-2017, 05:28 PM   #14
Classic! I just did it too. Posted a pic in the picture thread as well. I used an aluminum "beware of dog" sign as my bed cover. I cut it, bent it and reamed the holes accordingly.
Thanks for the inspiration DJMC!
Old 08-12-2017, 07:26 PM   #15
For the guys not using clips for the rear body mounts (flat rear beds), how are you keeping the body down?
I think I'm going to do a 2 window ute/pickup mod, with a half cage, lower side cage bars, black slightly sunken or flat bed (using aluminium sheet) and raised cage sides from the roof rack for the 'sides' of the bed (basically a hybrid of a few guy's designs which are all really awesome by the way). I'm going to try to use clips where possible.
Old 08-12-2017, 07:33 PM   #16
I only used the front clips, and the rear portion of the body seems to stay put nicely due to the pins that stick into the rear bumper. The whole upper body seems to want to stay put but if and when it wants to start walkin', I'll rectify the issue accordingly.
Old 08-12-2017, 08:28 PM   #17
I did the bed mod and kept cage and roof rack seems to work just fine and looks good too !!
crawlerRmy is offline   Reply With Quote
Old 08-15-2017, 07:57 AM   #18
CoolRunning I used the extra body mount that came with the truck, then used scx10 body posts they fit just right in the square holes, then the cut off roof I reused it for the bed cover, drilled two new holes, done deal., clips in the front an clips in the back all good an solid.
Old 08-16-2017, 07:39 AM   #19
Hollywood , its in the picture thread, number # 44
Old 08-17-2017, 07:29 AM   #20
It's been in the back of my mind since I finished the bed mod so I decided to add some proline threaded rear body posts very similar to these...They seem to work well.
Truck Bed Body Mod - Similar Threads
1 body fits 2 now, rs10 crawler with truck body 'mod' reelycrawler Paint and Body 0 06-03-2012 08:22 AM
Toy hilux body mod help-dove tail, bobbed bed ETC slashbasher 1.9 Scale Rigs 0 02-22-2010 03:17 AM
