05-14-2018, 08:20 AM | #1 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Magnets vs velcro vs clips
Hello everyone, trying to get my truck bed mod finished up & having trouble deciding how I should do body mounts for rear. I see allot of people saying that using magnets your going to have the body falling off. I don't want that for sure. I still have clips in the hood holding that on. I have room to do the clips, but would rather have something not visible. Only if it's going to work as good or better. Just wondering from your experience what's the best way to go? Thanks for any and all info! Have a great day!
05-14-2018, 09:49 AM | #2 | |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Magnets vs velcro vs clips Quote:
05-14-2018, 10:10 AM | #3 |
Magnets suck for off-roading. Any tip over and it'll dislodge the body in me experience. I keep the clips - simple and effective. |
05-14-2018, 11:52 AM | #4 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Small, 1/16 clips with a small washer under them look pretty scale on a 1/10, but velcro is invisible. Magnets are for drifters |
05-14-2018, 12:03 PM | #5 |
Thanks guys! I have some heavy duty velcro at the house I'll give a shot before I poke some holes in my bed liner. Really appreciate the knowledge!
05-15-2018, 04:54 PM | #6 |
Rock Stacker Join Date: Mar 2008 Location: Queens
I designed these body mounts to use 60mm x 10mm magnets. The part that attaches to the body captures the chassis mount so it can’t slide around. I just got the magnets and I plan on using either epoxy or shoe goo to hold he magnets in the mount. I think the weakest part of the system is the bonds between he layers of filament. I can update once I get the magnets installed and run it a few times. Sent from my iPhone using Tapatalk |
05-15-2018, 05:56 PM | #7 |
if you go the velcro route use Dual lock instead of the traditional velcro its much, much stronger. I just did up some magnetic body mounts for a hard body using ring magnets (rare earth) which are much better than those without a hole in the middle as they locate themselves. They're quite strong but I'm only using them here since its on a scale truck and should take a lot less abuse. |
05-16-2018, 07:02 AM | #8 |
I bought some velcro that's says it'll hold 15lbs I'm going to give it a try. Couldn't find the dual lock anywhere local. C-MuRdaA keep up the good work & please keep us posted on this. I'm very interested to see how it works out for you.
05-16-2018, 12:02 PM | #9 |
Rock Stacker Join Date: Feb 2017 Location: Tehachapi
Heavy duty velcro works for me.
05-16-2018, 05:56 PM | #10 |
Quarry Creeper Join Date: Feb 2016 Location: canada
If u use magnets use washers the the magnets r just big enough to fit in the middle of them they seem to wprk better Sent from my LG-M703 using Tapatalk |
05-16-2018, 11:20 PM | #11 |
Newbie Join Date: Mar 2018 Location: Halifax Nova Scotia
You can get all 3 done and decide which method you want to use each day. This will also give you option to use one way, 2 different combos or all 3 at the same time.
05-16-2018, 11:32 PM | #12 |
Uhhh... why would he ruin the body by making holes for body posts, then decide to go with velcro or magnets? |
05-17-2018, 07:16 AM | #13 |
| Re: Magnets vs velcro vs clips |
05-17-2018, 05:27 PM | #14 |
I installed the magnets yesterday. So far the mounts and the magnets are mounted using shoe goo in case I decide to change them up. I’m linking a quick video where you can get an idea of how strong the magnets hold. The front of my truck is super heavy so it’s easier to pop he body off that way. If the truck rolled down a hill and the body go caught up on something I have no doubt that the chassis would separate from the body. For a basic rollover these magnets (60mm x 10mm x 3mm will be fine. I have a few options. 1: use two magnets side by side to get more force to keep he body on 2: Make two more mounts (either with or without magnets) that hold the body on the sides that would help keep the body on. I would uses a similar style mount as pictured above but bolt it into the mounting space for the stock sliders. That part will bolt in and I’d make a “box” that would fit over it. I modeled that piece in about 20 min and I plan on printing it tomorrow and test fitting it before moving forward. Here’s a link to the current setup. https://youtu.be/NUMc_8YrVPw Sent from my iPhone using Tapatalk |
05-18-2018, 12:07 PM | #15 | |
Pebble Pounder Join Date: Oct 2016 Location: Philly Area
05-18-2018, 12:15 PM | #16 |
I made these little brackets that bolt into the holes for the stock sliders that will help keep the body on. Once the shoe goo cures I’ll take it for a test drive and see how my whole system holds up. Sent from my iPhone using Tapatalk |
05-21-2018, 05:45 PM | #17 |
With the four small mounts I added I can now pick up the truck by the body and it won’t come off. This truck weighs a ton too. I’m probably going to fine tune the new mounts and then post all the stuff I made on Thingiverse so people can print their own. https://youtu.be/5HxDA6dZJ4Y Sent from my iPhone using Tapatalk |
Magnets vs velcro vs clips - Similar Threads | ||||
Alternative to Body Clips - Magnet or Velcro? | ajsmcs | Axial SCX10 II | 16 | 12-20-2016 01:50 AM |
Magnets? | SMFtwstdHICK | Vaterra Ascender | 12 | 05-18-2016 10:51 AM |
Magnets | jetboat | Electronics | 9 | 01-18-2012 06:48 AM |
Magnets? | BJoe | Paint and Body | 19 | 01-08-2010 03:57 PM |
Magnets | LIKES2CRAWL | Electronics | 7 | 09-15-2007 11:31 PM |
