Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Another LED set for TRX4 controlled thru the TX
Old 10-08-2017, 11:39 PM   #1
Default Another LED set for TRX4 controlled thru the TX
I got a light kit including the controller and fixture also with the controller. the system is also water proof and only one servo cable connecting the body and the chassis. The down side is it dose not come with the light bar so I am planning to get the traxxas light bar.
The light has 3 modes :
1. All off (braking light will turn on while braking or neutral position depends if crawler mode is on)
2. small lights front, brake light on (low intensity) , brake light will be bright while brake applies
3. small light and main beam will be on, brake like same as point 2
These three mode can be alter using 3 times of steering left to cycle, which means can be controlled thru the tx without adding more which I found it is pretty brilliant.
Besides, the hazard light can be turned on/off by doing 3 times and steering right. Also it will be activated if the trx 4 is idle for more than 30 seconds, will be disabled when you touch the throttle again.
Of course it come with the turn signal and back up light as well.
I have done a short video demonstrating the cycle of the light mode with the tx.
ricksonchow is offline   Reply With Quote
Old 10-09-2017, 02:36 PM   #2
cartronicshn's Avatar
Default Re: Another LED set for TRX4 controlled thru the TX
These look like a cheaper alternative? they seem to work nice, where did you get them?
cartronicshn is offline   Reply With Quote
Old 10-09-2017, 11:17 PM   #3
Got it from China, about 50 bucks for waterproof version without shipping
Old 10-10-2017, 07:08 AM   #4
Looks pretty niffty, i like how its controlled and switched via steering inputs. care to provide a link to purchase?
Decaf is offline   Reply With Quote
Old 10-10-2017, 01:31 PM   #5
Awesome video. Do you know if the Traxxas version be able to do all these functions as well?
Slashrcgeo is offline   Reply With Quote
Old 10-11-2017, 12:07 PM   #6
https://world.taobao.com/item/556243...ucket=7#detail
Hope it helps, it is all in chinese though
Old 10-11-2017, 12:08 PM   #7
Seems not at the moment. No Hazard/turning signal for the traxxas at the moment and not able to control by the TX
Another LED set for TRX4 controlled thru the TX - Similar Threads
Led Lighting set feeeler tomjrscx10 Nevada 1 01-26-2012 08:14 PM
Custom LED set up instruction needed Gregorius General Crawlers 1 12-06-2010 07:09 PM
4 channel led set up help please derekshep Electronics 1 11-03-2009 12:53 AM
