11-29-2017, 11:44 AM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: high point
| Esc swap. No brushless
Has anyone tried a hobbywing 1080 in this unit yet? I'm sure most will say go brushless.....in not that guy.. Just have a brand new 1080 purchased for another build that has left the building...... |
11-29-2017, 12:16 PM | #2 |
| Re: Esc swap. No brushless
Search the site. The WP 1080 is well loved and I've been pushing brushed guys towards it since its release. You won't find a better brushed ESC at the moment at that price range. In fact, it's one of the best brushed ESCs right now at any price.
11-29-2017, 12:19 PM | #3 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
I run one in my TRX4. Works great. I also run them in 3 other trucks. Just do it....
11-29-2017, 04:34 PM | #4 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
When my ESC dies I'll be getting one (actually hoping it dies soon), this ESC is well liked and one of the most recommended. I've seen a few of them in action and the drag brake is amazing. here is a pic of the settings you can change on it. and for $42.00 you can't go wrong. https://www.hobbytown.com/quicrun-wa...112750/p564169 Features: Water-proof and dust-proof, suitable for all weather races. Small size, with built-in capacitor module. 100% Waterproof 15 programmable parameter items PWM Frequency: 1K/2K/4K/8K/16K Adjustable Freewheeling (DEO) capability Drag brake rate in 9 levels (adjustable) Electronic switch Aluminum case for great heat dissipation Great current endurance capability. Great built-in BEC output capacity. Automatic throttle range calibration, easy to use. Multiple protections: Over Voltage Protection Low voltage cut-off protection for battery Over-heating protection Throttle signal loss protection, and much more Risk-Free manufacturer's limited warranty available through Authorized Dealers in North America Specifications: Waterproof: Yes Dual Mode: No Fwd Cont. / Peak: 80A / 400A Rev Cont. / Peak: 30A / 180A Car Applicable: 1/8 - 1/10 Rock Crawler and Tank or Boat Motor Limit: Brushed Motors 540/550/775 Series 2S LiPo or 6S NiMH: ≥10T orRPM<30000@7.4V; 3S LiPo or 9S NiMH: ≥16T or RPM<20000@7.4V Battery: 2-3S LiPo or 5-9S NiMH BEC Output: 6V/7.4V @ 3A (switch mode) PWM Frequency: Adjustable 1K/2K/4K/8K/16K Wires: 14AWG-200mm w/ XT60 Connector Size/ Weight: 36.5(L)* 32(W)*18(H) (without fan) External Program Port: External Program Port Available Programming: LED Program card Cooling Fan: Without cooling fan Weight: 58.5g |
11-29-2017, 05:10 PM | #5 |
Yes,I have 2 myself........that's why I asked.... My worry was the micro servos may be more prone to damage if pumping high amperage to them. That's all......I know the 1080 well.and having a new rig with a brushed setup.I would only want one esc in it.. |
11-29-2017, 05:46 PM | #6 |
| Re: Esc swap. No brushless To avoid this I used an external BEC and a RX Bypass Adapter so that I'm only volting up the steering servo and not the others.
11-29-2017, 08:09 PM | #7 |
Well,the whole thing behind an esc with a great bec in it is to avoid all the extra electrical items in the system..
11-29-2017, 08:35 PM | #8 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: Esc swap. No brushless |
11-29-2017, 11:13 PM | #9 | |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Esc swap. No brushless Quote:
Gesendet von meinem Pixel 2 XL mit Tapatalk | |
12-08-2017, 08:17 AM | #10 |
Pebble Pounder Join Date: Aug 2015 Location: Jackson
| Re: Esc swap. No brushless I just put one in mine.. I love it so far. I'm running it with the stock motor on 3s. I think power is equal to or better than stock, but the adjustments you're able to make with the program card make it far better than the Traxxas ESC.
Esc swap. No brushless - Similar Threads | ||||
scx10 esc swap | Ducky | Newbie General | 5 | 01-03-2015 12:04 AM |
Sidewinder 3 swap for stock ESC? | motopreserve | Axial Yeti | 8 | 10-17-2014 06:38 PM |
Need advice on lipo and brushless swap. | YelloTJ | Electronics | 25 | 10-31-2011 07:21 PM |
