12-19-2017, 09:11 PM | #1 |
Rock Stacker Join Date: Apr 2016 Location: Fort McMurray, AB, CAN
| SSD Servo Horn
The SSD00224 Servo horn hits the panhard bar with the stock setup and wont let the left side suspension fully articulate. Back to stock servo horn until I can relocate the servo |
12-20-2017, 03:28 AM | #2 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD Servo Horn
I dont think it actually touches as I can see a tiny gap between them on my test rig, also it articulates fully. Maybe different servo is slightly lower?... some M3 washers will raise your servo by 0.5mm. Easy fix. |
12-20-2017, 04:29 AM | #3 |
Pebble Pounder Join Date: Jan 2017 Location: Brookfield
| Re: SSD Servo Horn
Your servo seems to hang a bit lower than the stock one. The stock one is flush with the mount yours doesn't seem like that unless outs the picture. Here is mine with the stock servo and ssd horn. The first pic is full lock left and full articulation it doesn't touch. Hope this helps Sent from my SM-N950U using Tapatalk |
12-20-2017, 05:09 AM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: SSD Servo Horn
Its the servo, even though there is a "Standard" size, they all fluctuate on dimensions some. As mentioned, simply put spacers under the servo on the servo mount. I had to do this to accomodate for a servo arm, not servo. Sadly no one makes the TRX horn I need (23T). |
12-20-2017, 06:38 AM | #5 | |
| Re: SSD Servo Horn Quote:
https://www.amainhobbies.com/samix-t...022k-s/p722955 | |
12-20-2017, 01:40 PM | #6 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: SSD Servo Horn
that looks nice, too bad they left 24T out of the mix. WTF Tekno makes a nice 0 offset horn, but they stopped making 24T. https://www.teknorc.com/shop/tkr5251...rn-23t-spline/ |
12-20-2017, 06:52 PM | #7 | |
Love the front and rear bumpers BTW. | |
12-20-2017, 06:57 PM | #8 | |
SSD Servo Horn - Similar Threads | ||||
New SSD Aluminum Servo Horn for TRX-4 | SSD | Traxxas TRX-4 | 31 | 04-09-2018 06:57 PM |
OFNA Servo Horn stout enough for Protek 170T Servo? | Banjoblue | Axial Wraith | 2 | 06-25-2015 05:30 PM |
