02-14-2018, 03:17 PM | #1 |
Newbie Join Date: Feb 2018 Location: SoCal
| Big bore aluminum shocks
Have anyone run these shocks? How are they comparing to stock? One of my front shock is dropping to one side. Sent from my iPhone using Tapatalk |
02-14-2018, 04:45 PM | #2 |
| Re: Big bore aluminum shocks Are you saying your truck is leaning to one side? If so, I seriously doubt you need new shocks. The stock TRX4 GTS shocks are actually quite good shocks but you do need to disassemble them, clean them, adjust and lube the O-ring seals with "Green Slime" and refill with a lighter wt shock oil. If you have one corner of your rig that is drooping you simply need to adjust the spring tension to level the ride. Last edited by Inspector86; 02-14-2018 at 06:18 PM. |
02-14-2018, 05:31 PM | #3 | |
| Re: Big bore aluminum shocks Quote:
Actually, I don’t have the stock shock, bought the rig used and came with these shocks. I dissembled the shocks and filled with 20t oil. The side that droop was leaking so now I run without oil. I’m thinking changing to big bore shock and get the stock shocks but sure which to get. Thanks Sent from my iPhone using Tapatalk | |
02-14-2018, 05:53 PM | #4 |
For future reference, when you ask a question it helps to include all the relevant information. That said, throw those junk shocks in the thrash and buy yourself a set of stock TRX4 GTS shocks or, if you really want a nice smooth set of shocks, buy a set of Dluxfab shocks with medium springs which are actually modified Big Bore shocks. Dlux Fab Last edited by Inspector86; 02-14-2018 at 06:29 PM. |
02-16-2018, 09:04 PM | #5 | |
Rock Stacker Join Date: Sep 2017 Location: in a RV
02-16-2018, 09:12 PM | #6 |
I'm actually running 10wt in my 2661 Big Bore shocks and it fits my slow driving style perfectly. I don't think I would like a heavier oil, the truck just feels sluggish to me with heavy oil. Like someone said, you can inspect 20 trucks from 20 owners and no two of them will be setup the same way.
