03-03-2018, 06:34 AM | #1 |
Newbie Join Date: Feb 2018 Location: central
| glitch buster
i replaced stock steering servo with savox 1210sg and like the torque much better! my stock servo actually went out within 2 battery packs. i cant find much info on glitch busters tho, do these get rid of the static when i first turn the truck on or when im on a rock at a weird angle the servo is noisy unless i constantly try to straighten the wheel
03-03-2018, 07:29 AM | #2 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: glitch buster
Savox servos are the noisiest servos out there, a glitch buster is not going to do anything for it. Nothing wrong with the servo, just a character of Savox servos when hunting for center. Don't waste your money or time on a glitch buster, make sure you get a C.C. 10 amp BEC if you don't have one already. The stock esc BEC is laughable at 1 amp. |
03-03-2018, 07:30 AM | #3 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: glitch buster
That’s not glitching...that’s the nature of a digital servo trying to find centre. Annoying ain’t it! I just lift the truck so it settles if am sat having a brew on the trail. :-)
03-03-2018, 09:23 AM | #4 |
Rock Stacker Join Date: Jan 2018 Location: Madison
| Re: glitch buster
I need to go trailing/crawling with you oOwizOo... a brew on the trail sounds nice! @Zerocool91 you really need a BEC with the stock ESC or you will eventually burn it up. I burned mine up a couple of runs after installing a Savox 1230sg. You could just cut the chase and sell your stock ESC, skip the BEC and buy a Hobbywing 1080 crawler ESC. It is so much smoother, has more setting options over the stock ESC and it is about half the price to boot. |
03-04-2018, 05:12 AM | #5 |
Pebble Pounder Join Date: Jan 2017 Location: Brookfield
| Re: glitch buster
I have the same servo in my truck. I would recommend setting the end points. The sa savox are noisy but you could also be pushing the servo far and stressing out the steering parts which makes it noisier. I used a glitch buster from spektrum as a precaution. I then switched to a water proof castle bec to bring up the voltage on the servo. Sent from my SM-N950U using Tapatalk |
glitch buster - Similar Threads | ||||
When to Use CC BEC vs. Glitch Buster? | alexchen86 | Electronics | 7 | 05-12-2013 01:32 PM |
Glitch Buster Opto-Isolator | CoolRC | Electronics | 7 | 07-28-2010 10:58 AM |
Novak Glitch Buster Capacitor | nickhpiracing | Electronics | 4 | 06-17-2009 06:39 AM |
novak glitch buster | ohmyCLOD! | Electronics | 1 | 12-24-2008 11:32 AM |
