Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: trx4 reverse problem
Old 05-26-2018, 06:38 AM   #1
Default trx4 reverse problem
I have to hit the trigger a couple to a few times to get reverse to engage on my stock trx4. ANyone know the problem?
jahlion247 is offline   Reply With Quote
Old 05-26-2018, 06:53 AM   #2
Moderator
JatoTheRipper's Avatar
Default Re: trx4 reverse problem
If you look in the manual it shows how to get it into crawler mode so you have instant reverse.
Old 05-26-2018, 07:29 AM   #3
Mine did that. It was the ESC failing. Replaced it with a Hobby Wing 1080.
o0wiz0o is offline   Reply With Quote
Old 05-26-2018, 08:56 AM   #4
Mine did the same thing - new ESC.
cjhike is offline   Reply With Quote
Old 05-26-2018, 09:07 AM   #5
Gold Star Baby!
Topher Builds's Avatar
If it is brand new and you haven’t changed the driving mode i’d suggest you try what Jato said, it’s page 20. You’ll see crawler mode has instant reverse.
That aside, it is never a bad idea to upgrade from a XL5 to a HW1080.
Topher Builds is offline   Reply With Quote
Old 05-26-2018, 02:14 PM   #6
cartronicshn's Avatar
I 've had zero issues with my defender except for steering servo, the bronco which is brand new,had a defective receiver that acted like what you describe, although on mine it is the receiver the problem, once the receiver recognizes the radio, i have no problem in forward but reverse i have to play around for it to work. The same radio on the defender works flawlessly.
cartronicshn is offline   Reply With Quote
Old 07-29-2018, 05:21 PM   #7
I had the same problem with my trx4 not reversing all the time.
Mine was a problem with the trigger centering on the remote.
I adjusted the throttle sub trim in the traxxas app ~1 to the reverse and it fixed it.
knarf118 is offline   Reply With Quote
trx4 reverse problem - Similar Threads
Reverse problem calikingcrawler Axial AX-10 Scorpion 3 03-14-2009 04:28 PM
reverse problem mudrinner4ever General Crawlers 2 06-24-2006 12:41 PM
