07-10-2018, 08:12 PM | #1 |
Newbie Join Date: Jun 2018 Location: Newnan
| New Sport has arrived!
Today I came home and my TRX4 Sport was delivered. After reading up on the instructions, I took her for a spin on some rocks. I put some scratches on the new body but man was it a blast! I’m also running the Traxxas 3s Lipo 5000mah battery and it lasted a long time. I’m only used to rc’s Lasting 15 to 20 minutes before it dies. I’m just now getting back into rc and I opted to get the Traxxas live ID charger. It is very fast and simple to use, plus you can adjust a lot from the app. My only concern is later on if I want to upgrade the esc or motor, will the battery and charger still be comparable? I also noticed the Servo was kind of weak but it’s fine for now until I figure out a good upgrade. I was going to post pics but apparently I can’t or at least not for a phone. Last edited by OperatorB; 07-10-2018 at 08:15 PM. |
07-10-2018, 08:53 PM | #2 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
| Re: New Sport has arrived!
Welcome, you’ll enjoy it. There are a lot of terrific people on RCCrawler and will help you out with whatever you need. You can use any esc with the Traxxas batteries, all that needs to be done is to purchase a plug adapter or solder on a Traxxas connector. The 2075X servo is very weak and will have a short life. I would not buy a servo under 250 oz/in. Depending on the size servo you will want to pick up an external bec. A good one that almost everyone runs is the Holmes Hobbies 10 amp. When you purchase a new servo get an aluminum servo horn from either Traxxas, Samix or HotRacing those are the only companies that offer horns with the 22mm hole to hole spacing that the TRX4 uses...I’d just get the Traxxas one, it’s $6. Since you are just getting back into r/c take a look through the Guide to the TRX4 thread that’s stickied above. |
07-10-2018, 08:59 PM | #3 | |
| Re: New Sport has arrived! Quote:
Thank you for the advice. Would you solder the traxxas connector on the battery or the esc? I didn’t think you could but Traxxas ID connectors. | |
07-10-2018, 09:08 PM | #4 |
You would solder the Traxxas connector on the esc, the battery uses its ID connector for the charging and storing functions with the charger only. The esc only needs a + and - . It’s just the standard connector that the esc uses. If you decide later to upgrade and get a new esc the one that most get is the HobbyWing 1080. Also if you decide to post pics, I use Flickr and share with the embed code. Pics should be in the medium sizes I usually use 800 x 600 that way you can just paste the code and not use the pic tool in the post header toolbar. Last edited by ScoJac; 07-10-2018 at 09:15 PM. |
07-10-2018, 09:17 PM | #5 | |
That’s good to know. I was worried I wouldn’t be able to use all the functions of my charger due to me having to go to a deans or x60 connector. | |
07-11-2018, 04:10 AM | #9 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
Welcome to the Trx-4 addiction bro! Ask anything you need. Allot of great people on these forums.
07-11-2018, 05:44 AM | #10 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
I have 2 TRX4's and I love 'em! The Sport should prove a ton of fun and it already boasts a ton of aftermarket support. I initially went with a Traxxas 5000 mah lipo and ID charger but I also use other batteries with XT60 connectors into the stock Traxxas ESC ( with an adapter). I went with a SkyRC IMAX B6AC charger to charge the XT60 equipped batteries and the only thing that I had to do was to get an XT60 to Traxxas adapter for my rigs ( 2 pack is under $5 on ebay). The IMAX B6AC is imo a much better and comprehensive charger than the Traxxas charger and is only about $45. I still use the ID charger with the Traxxas battery but if you plan to eventually run other batteries, the IMAX is a great quality charger for the money. It also comes with a lot of adapters to charge a variety of batteries with Deans, EC3, XT60, etc connectors. This is the adapter that I plug into my stock ESC in order to run other XT60 batteries: Also I doubt that your stock steering servo is going to last very long. There are some great servo choices out there but the DS3218 is a decent replacement for cheap ( less than $18 ). It's not the strongest but it seems to have much better reliability and a bit better torque than the stock Traxxas servo. The ProModeler 470 also seems to be gaining popularity in the $100 +/- servo arena with a ton of torque but I think that they're unavailable at the moment. Savox is a very popular brand with the crawler crowd as well. There is a great thread here on RCC regarding cheap servo's... Tons of good info in this thread when you're ready to look into upgrading. What the newest cheap servo hotness? Last edited by high plains drifter; 07-11-2018 at 05:47 AM. |
07-11-2018, 07:47 AM | #11 |
Post photos! Congrats on the Sport. The TRX-4 is awesome. Your battery and charger should be fine for a long time unless you go with some insane brushless system that wouldn't be good in the TRX-4 anyway. Moving forward just be aware you can get much better and less inexpensive batteries if you avoid Traxxas. Companies sell you better batteries for lower prices and some of them will even solder a Traxxas connector on for you. |
07-11-2018, 10:05 AM | #12 |
| Re: New Sport has arrived! |
07-11-2018, 10:12 AM | #13 | |
Thank you. That is good to know and a relief. For now the motor is fine but I would like to upgrade the Servo soon. From videos on YouTube, it appears you have to modify the servo in order to fit the upgraded servo in place. Is that true with all servos for the TRX4? | |
07-11-2018, 10:36 AM | #14 | |
https://www.rpphobby.com/product_p/yea-trx4-005bk.htm Oh and just a hint - you can embed your images so people don't have to click on links or download them, but they have to be 1200 pixels or smaller. Last edited by JatoTheRipper; 07-11-2018 at 10:42 AM. | |
07-11-2018, 10:45 AM | #15 | |
Yeah I’m using Flickr and I don’t know how to make them smaller. I’ll have to read up a bit on how to do that. Other forums were a little easier to post pics. I’d did post some pics on this thread but they were huge. About the mount, that looks like a good idea and I’d rather do that then modify plastic. Is there any YouTube or instructions on how to install the mount? | |
07-11-2018, 10:57 AM | #16 | |
07-11-2018, 11:24 AM | #17 | |
Thank you for letting me know. | |
07-11-2018, 11:41 AM | #18 |
Got it!!! Thank you for showing me how to do this. CF188774-79F8-4BE5-8F8C-C6F45D489197 by brandon kline, on Flickr 6064DE73-9748-4607-9A45-8E65394FBA6B by brandon kline, on Flickr 989B75DC-69EA-4BAD-B485-3AC1A6F2C3F8 by brandon kline, on Flickr F0C1933E-EA4D-4F17-A2F6-428FA04F3423 by brandon kline, on Flickr 2301B632-1624-44A6-8EBB-9CA65437383E by brandon kline, on Flickr |
07-11-2018, 11:59 AM | #19 |
07-11-2018, 02:21 PM | #20 |
New Sport has arrived! - Similar Threads | ||||
It has arrived | Motorider | Traxxas TRX-4 | 7 | 11-08-2017 10:57 AM |
It has arrived. | Angus_Beef | Axial Yeti XL | 21 | 03-14-2015 10:56 AM |
She arrived... | jbsmith05 | Newbie General | 12 | 04-05-2013 07:15 PM |
Jr Has arrived | hende | Chit Chat | 7 | 03-19-2012 09:42 PM |
My CR-01 Has arrived | BLUE 2 | Tamiya CR-01 | 2 | 05-11-2008 11:53 PM |
