Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Trx4 service truck
Old 10-15-2019, 08:06 PM   #1
Default Trx4 service truck
Looking at building a scale copy of my work service truck. Anyone have any tips or examples of one that's been made already?
Sent from my SM-N960W using Tapatalk
Youngblood00 is offline   Reply With Quote
Old 10-15-2019, 08:11 PM   #2
Moderator
JatoTheRipper's Avatar
Default Re: Trx4 service truck
Proline used to make a body that would be perfect. Here's the box half, but it's discontinued so check eBay.
https://www.prolineracing.com/bodies...clear-body.asp
Old 10-15-2019, 08:15 PM   #3
I've been looking at those and found them on ebay for a decent enough price. Only issue I have is the style isnt quite tall enough. So not quite scale. You think I could stack two and it would look right?
Old 10-15-2019, 08:18 PM   #4
Moderator
Anything is possible of you're willing to work. You can also hand build it from scratch using styrene.
Old 10-15-2019, 08:21 PM   #5
That may be what I do. Pick up the ford cab from proline and lay out the service body best I can. Even thinking maybe I can make the crane somewhat operational as well
Old 10-15-2019, 08:23 PM   #6
Moderator
You could definitely make a crane work. The construction side of RC is huge and I'm sure they have something that would work.
Old 10-15-2019, 08:29 PM   #7
I guess my first course of action should be to buy the cab and go from there
Old 10-26-2019, 04:26 AM   #8
So I measured and scaled down the service body. Made a cardboard sample to test out the dimensions with the new chassis. Looks like it should do the trick just fine. Now to decide how to proceed building the service box.
Old 10-26-2019, 04:50 AM   #9
Moderator
Cardboard is the perfect test build material. Nice job. I still think Styrene will be your best bet.
Old 10-26-2019, 06:19 AM   #10
Cool, I like those rims too!
aqualungs is offline   Reply With Quote
Old 10-26-2019, 07:46 AM   #11
indybama's Avatar
This is goina b good from wat im seein. Watchin this one!
Sent from my SM-J327VPP using Tapatalk
indybama is offline   Reply With Quote
Old 10-26-2019, 06:47 PM   #12
Styrene really is pretty easy to work with, and I think it'd be your best bet for that box-bed. Check out the Scale Accessories section ... roksloski does some amazing chit with it! You might get some ideas or pointers in his thread.
Lookin' good so far.
jim
dr frankenstyle is offline   Reply With Quote
Old 10-27-2019, 04:17 AM   #13
So I wanted a bit more detailed layout. So I picked up some foam board. I've managed to figure out the mounts for it and worked out some details of the body. Not sure if I'll just keep the foam board as its actually way sturdier than I expected. I do hope to mount a "working" crane on the one side so we'll see how that holds up.
Included a chassis shot because why not? Details on the chassis are simple. I originally bought the trx4 builders kit and a long arm lift kit, then ordered up traxxas parts 8830 - trx6 crossmember, and 8829 - trx6 chassis rails. And shifted the crossmember to where I wanted it to achieve the wheelbase I was after. In this case it sits a bit longer than 17inches.
The wheels are from ssd. Just a basic beadlock with the OEM traxxas tires. I'd like to run a dually setup but I'm already going to hurt the trailability of the trx4 by making it so long I'll just leave it as is.
Old 10-27-2019, 04:41 AM   #14
Great looking build. I did something similar in size with a bruder flat bed and a truck cab, similar wheelbase.
alexleblanc is offline   Reply With Quote
Old 01-20-2020, 10:59 PM   #15
I apologize for the lack of updates. I'm slowly tinkering with this build. Just got some lazer cut mdf for my service body. I think it's the best option for this rig. Should be decently durable and once I figure out how to mount it and my rear shocks and adjust the wheelbase etc etc.
But I'm going to glue it all together and wrap it in that aluminum duct tape then obviously paint it. I still have a few other things to get built. Air tank, light bar, spare tire mount, generator/compressor, cabinet and most importantly a crane which I hope I can manage to make operational. Lots too do and little time to actually accomplish any of it.
I included a picture of my driveshaft setup using an lesu steady bearing
Old 01-22-2020, 09:42 PM   #16
Coming along good. Who needs a winch on a bumper when you have a crane on top and can pull yourself out of any situation in any direction, lol.
Levi is offline   Reply With Quote
Old 01-22-2020, 09:57 PM   #17
Haha hardest part will be making sure the mounting is strong enough for that
Trx4 service truck - Similar Threads
Vinyl Decals...Forestry Service or Fire Truck sawhead Paint and Body 7 12-25-2017 03:05 PM
zonks cat service truck zonkerd Axial SCX-10 67 02-02-2014 02:20 AM
My UNIMOG service truck diritnot Tamiya XC/CC01 15 12-07-2012 10:59 AM
Roadside Service truck microgoat 1.9 Scale Rigs 2 02-27-2009 10:43 AM
