05-03-2021, 10:32 AM | #1 |
Newbie Join Date: Apr 2020 Location: South Shore
| Larger Receiver/Electronics box
Hi All, Does anyone know if Traxxas or anyone else makes a larger receiver/electronics box cover? If not, is there any alternative waterproof box that is larger? Thanks |
05-03-2021, 01:00 PM | #2 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Re: Larger Receiver/Electronics box
Not many larger than the Trx box. You can have a box extension 3d printed. As far as waterproof box. Good luck! You're better off waterproofing your electronics. I used a second box. I believe it was from a revo and mounted it in front of the servo and made an extension for it. You can see pics of it in my build thread. Somewhere in the last few pages. Good luck!!! Have a great day!!! Sent from my iPhone using Tapatalk |
05-03-2021, 02:13 PM | #3 |
Rock Crawler Join Date: Apr 2020 Location: Drums
Not sure if this would work for you but Traxxas makes a larger receiver box cover that can make the stock TRX4 box taller. https://traxxas.com/products/parts/8224X |
05-03-2021, 03:36 PM | #4 |
Quarry Creeper Join Date: Nov 2020 Location: Greece
Why do you need a larger box?
05-03-2021, 05:11 PM | #5 | ||
| Re: Larger Receiver/Electronics box Quote:
I have a Futaba TX/RX that has less channels than needed. I wired some servos together and added servo reverses where needed. With one button press I go from 2nd gear with no diffs locked to 1st gear with everything locked. That way I control lights with the other available channel. The wiring and servo reversers make it very tight inside if not impossible to close. | ||
05-03-2021, 05:14 PM | #6 |
Hmmm, if height is not a problem, maybe the best option would be to get a 3d printed one and some seal rings to waterproof it.
05-06-2021, 07:02 PM | #7 |
Rock Crawler Join Date: Apr 2017 Location: US
Traxxas receiver boxes are really good. Something bigger, the best that I could find was a rc4wd #z-s0592 box. Bad thing it's not waterproof. But one could use a little rtv or something to seal it. I like it, I have it on my trailfinder and some other builds for a winch controller. Sent from my SM-A516U using Tapatalk |
05-07-2021, 12:55 PM | #8 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
05-07-2021, 10:23 PM | #9 |
Thinking about drawing up an extension for the RX box, how high would you want it extended? I am thinking 10mm is about right, but it all depends on what you are wanting to stuff in there. TRX4_RX_EXT v2 by Scott O, on Flickr Last edited by Greatscott; 05-08-2021 at 02:54 PM. |
05-08-2021, 10:11 PM | #10 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
| Re: Larger Receiver/Electronics box Someone already thought of this, JoeLine on Shapeways has two different heights available.
05-08-2021, 10:19 PM | #11 |
Unsure what the trx4 has, but traxxas has a few different sizes of rx boxes throughout their vehicle lineup.
05-09-2021, 10:54 AM | #12 | ||
05-11-2021, 07:55 PM | #13 |
Pebble Pounder Join Date: Oct 2019 Location: Saint Louis
| Re: Larger Receiver/Electronics box Sent from my iPhone using Tapatalk |
05-12-2021, 04:25 PM | #14 |
| Re: Larger Receiver/Electronics box WOW, they one is a monster!!! Is it water-tight, and if so, how did you seal it? As far as my design goes, if interested, here is the file on Thingiverse. https://www.thingiverse.com/thing:4857142 Let me know if you'd like a different extension length. |
05-23-2021, 12:05 AM | #15 |
A quick update. A few people have asked me about this design, and requested taller extensions. I have modified the 10mm design, adding 15, 20, 25, 30mm extensions. For waterproofing, highly recommend an internal and external layer of conformal coating. Also, recommend testing for water tightness before you trust it to keep your electronics dry. |
05-24-2021, 06:19 AM | #16 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
the one for the Enduro is pretty big.
05-24-2021, 06:35 AM | #17 | |
It uses the stock rubber o-ring but that only seals one side of it (top or bottom of the extension). I’d recommend silicone to seal it up better. Sent from my iPhone using Tapatalk | |
Larger Receiver/Electronics box - Similar Threads | ||||
Capra Receiver Box/Electronics Layout | Still Bill | Axial Capra | 2 | 10-19-2019 03:25 PM |
Need a larger "receiver" box... | skybolt | Electronics | 5 | 03-07-2015 09:36 PM |
Could star holding members get a larger PM box? | Etype R | Comments, Suggestions, and Help | 32 | 01-03-2007 04:05 PM |
