Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Rear signals not working
Old 09-02-2022, 11:41 PM   #1
Default Rear signals not working
I got a used trx4 bronco with the lighting kit. I had to clean the main module on the car with contact cleaner because headlights didn't work. Now ive got the front signals to work but no rear. Is there something else in missing?
https://youtube.com/shorts/Bbm9Vkbm2Y0?feature=share
Sent from my SM-F926W using Tapatalk
sasq40 is offline   Reply With Quote
Old 09-03-2022, 09:58 AM   #2
Default Re: Rear signals not working
Did you install the short plug on F of the distribution block in the body?
This is what makes the rear lights blinkers too.
You can get manuals on the pro scale kit @traxxas.com, see https://traxxas.com/products/parts/6591?t=support and there are drawings and explanations.
amigaman is offline   Reply With Quote
Old 09-03-2022, 10:55 AM   #3
I think the previous owner had it hooke dup wrong. From my understanding you don't use the maxx link with the Rx in. Can you use the maxx link cable without the Bluetooth? I feel like the lights are on the wrong spots on the rx
Old 09-03-2022, 11:53 AM   #4
The Maxxlink is for Traxxas Rx, the servo connector for non-Traxxas Rx. Dunno if you can use both parallel, manual says "optional" on the Maxxlink but does not show servo connectors to the Proscale.
It does not have to do anything with the bluetooth Link, except that using the App to power additional lights only works with the Maxxlink.
But i see you're using the Maxxlink plug on the Rx but Rx-In on the Proscale. That's not ok, Rx-In is for the Servo wire, Maxxlink comes to the Maxxlink-In port. I can't imagine why it still reacts to the steering...
Or does it seem you have the servo wires connected to the Rx-In and another Maxxlink ending in nirvana? Maybe additional sensors or so? Can't see clearly what you have in the Rx box.
Maybe you should take a look where all the wires go and check with the manuals i linked above.
Also, on the Distribution Block are some wrongs, but most is ok:
A is used for reverse lights. Not used in your case, did you not fit them?
C (rear lights) and D (rear markers) seem ok.
G and H are for front lights, seems ok although H could need a refitting i'd say.
The short plug on F is missing, and that's what makes your rear lights work as blinkers. Without it you'll need some extra Blinkenlights plugged into another port, but that's for bodies that have them.
Old 09-13-2022, 12:29 AM   #5
("Hijacking" this thread for a similar problem...)
I want to attach a bumper light bar, #8088, to the "Pro" power module. The manuals don't say where to attach it, but to consult Traxxas' support site.
Traxxas' support site only contains the manual refering to that site...
So, do I use the adapter similar to that used for the roof bar (8087)?
What output(s) (of the 10 or so available on the power module) should I use?
Olle P is offline   Reply With Quote
Old 09-13-2022, 02:06 PM   #6
Found the answer to my question!
The answer was in the manual for the Pro installation kit 8083.
Rear signals not working - Similar Threads
Sequential Turn Signals heyok Electronics 2 04-29-2016 12:14 PM
Got Hand Signals? EeePee Chit Chat 0 02-01-2008 02:02 PM
Rear Axel not working? Stein General Crawlers 2 11-30-2006 11:12 AM
Rear axle not working!! stx4wheeler General Crawlers 4 03-01-2006 12:07 AM
rear wheels not working.... elkie General Crawlers 1 02-21-2006 07:49 AM
