Go Back   RCCrawler Forums > Competitions and Events > U4RC
Thread: Yeti Racers: shock setup?
Old 02-15-2015, 10:29 PM   #1
~THE SCALE SHOP~
Question Yeti Racers: shock setup?
looking for some direction from those that actually race and tune on there yetis.
shock setup. I feel like mines leaving a lot to be desired.
Oil?
Springs?
Preload amount?
advice?
Thanks
Cory
STANG KILLA SS is offline   Reply With Quote
Old 02-19-2015, 08:55 AM   #2
Default Re: Yeti Racers: shock setup?
I run a heavy oil.in mine 55 rear and 60 up front. I also use hot racing yeti springs in the rear the green ones and im using limiting straps all the way around too.. Mines unstoppable until something breaks.lol.. Im constantly tuning my rigs.. This setup is almost perfect for U4 racing in auburn..hope thus helps alittle..
Rastaman is offline   Reply With Quote
Old 02-20-2015, 09:20 PM   #3
i think the heavier oil is defiantly the way to go. im running 40 up front and 50 in the rear, stock springs in the rear and stock slash white springs up front... ill be adding the limit straps as well.
how about input on shock location
poop is offline   Reply With Quote
Old 02-21-2015, 09:10 AM   #4
Poop, one rule of thumb is you always want a thicker weight inthe front over the rear. If you switch that weight up it wil handle even better.. If your jumping it then you really want that heavier weight oil.in the front..
As far as shock location i put the front top screw all the way on the inside mount location and rears i keep in the stock location..
Old 02-22-2015, 09:01 PM   #5
thanks..I'll give it a shot
Old 03-21-2015, 12:12 PM   #6
Stock shocks, any piston changes ?
hotwheels000 is offline   Reply With Quote
Yeti Racers: shock setup? - Similar Threads
Yeti shock oil weights? skybolt Axial Yeti 14 03-16-2016 06:14 PM
Yeti shock clips 4X4 Freak Axial Yeti 4 01-06-2015 09:47 AM
