Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: Headlights
Old 12-23-2019, 11:10 AM   #1
Default Headlights
My Origin and Pro are almost perfect. The only thing missing are Vanquish Rigid Q-series headlights. I haven't seen these available in a while and wondering if/when they will come back into production.
dna930 is offline   Reply With Quote
Old 12-31-2019, 11:45 AM   #2
Im Brandon
Brandon's Avatar
Default Re: Headlights
Should have them available again early 2020.
Brandon is offline   Reply With Quote
Old 01-06-2020, 11:40 PM   #3
Cool.
Brandon, I'm trying not to think to far ahead since the lights are not available yet, but is the front bolt pattern of the Rigid light the same as the screw holes in the Origin and Pro body? If so, is installation of the lights in the body as simple as using longer screws and installing in place of the existing headlight bucket? Also would you have to remove the center of the headlight lexan from the body due to cooling issues since the Rigid lights output over 600 lumens?
Thanks.
Old 01-07-2020, 03:58 PM   #4
Im Brandon
Brandon's Avatar
Originally Posted by dna930 View Post
Cool.
Thanks.
Bolts right in using existing screws. No need to remove the lexan lens. If you want to install the aluminum trim/bezel piece in addition to the molded grill you will need a longer 1/64 screw. Cant say I have seen anybody do that though.
Old 01-08-2020, 04:36 PM   #5
Moderator
JatoTheRipper's Avatar
How early? Can I preorder?
Old 01-09-2020, 02:47 PM   #6
Im Brandon
Brandon's Avatar
Ill narrow it down to Q1.
Old 01-09-2020, 03:24 PM   #7
Moderator
Fair enough.
Headlights - Similar Threads
headlights malibu jim RC4WD Trail Finder 2 2 07-14-2014 06:45 PM
Headlights Hylton Axial SCX-10 3 01-18-2013 01:45 PM
