04-22-2020, 06:45 PM | #1 |
Quarry Creeper Join Date: Feb 2017 Location: Adirondack Park
| Servo On Axle
Anyone found a mount to put a steering servo on a Vanquish front axle that works well? If you did what vanquish axle and mount did you use. Well I read it and realized what I wrote was pretty vague, was wondering if there was a axle that worked better for you than another. At this time I have a set of F9's or D44's but is there one that worked better I have not mentioned?
04-26-2020, 05:55 PM | #2 |
Pebble Pounder Join Date: Dec 2004 Location: Acton
| Re: Servo On Axle
Do you have an offset venter section? Like what come on the pro/origin/ultra. If so then I don’t believe anyone makes a servo on axle mount. There’s nowhere to really mount the servo there. If you have the centered center section versions they make a SOA Mount for those. If you have rockjocks shapeways make a SOA Mount for those.
Servo On Axle - Similar Threads | ||||
Servo on axle mount | Desmo | Traxxas TRX-4 | 2 | 08-20-2019 07:16 PM |
Axle mounted servo? | goobs | Traxxas TRX-4 | 13 | 10-19-2018 05:08 PM |
Axle servo vs chassis servo | moyoman202 | Axial SCX-10 | 15 | 04-28-2018 11:17 PM |
steering servo off the axle | robsyz426 | Axial Wraith | 31 | 12-22-2011 12:02 PM |
Axle flex with axle brace mounted steering servo? | NoOb | Tamiya Clod Buster | 6 | 02-19-2006 11:04 AM |
