Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: Ultra VVD part number replacement
Old 06-28-2020, 06:23 AM   #1
Default Ultra VVD part number replacement
While out crawling the other day (second battery through the Ultra) I managed to snap the short side VVD axle shaft. Can anyone verify the correct replacement part number (I'm at work and don't have the manual with me)? And does anyone know if I can buy just the one (or even just the inner shaft) that broke? It's a clean break on the tang where the axle inserts into the spool.
Thank you in advance!
Lashlee is offline   Reply With Quote
Old 06-28-2020, 06:53 AM   #2
Go Buckeyes!
B-MOW71's Avatar
Default Re: Ultra VVD part number replacement
Looks like part #VPS08356. I only see them coming in a set.
B-MOW71 is offline   Reply With Quote
Old 06-28-2020, 03:35 PM   #3
Thanks Brian! I went ahead and ordered a set. Hopefully they will get here within the next few days.
Old 06-28-2020, 05:43 PM   #4
Go Buckeyes!
B-MOW71's Avatar
Your welcome!
Ultra VVD part number replacement - Similar Threads
what's the part number tundrafan01 General Scale Talk 2 10-09-2011 08:27 PM
part number? KrawlerKing Team Losi Comp Crawler 1 02-04-2010 06:33 AM
Need part number? cward Losi Mini-Rock Crawler 1 01-22-2009 09:40 PM
Part Number? Reef General Scale Talk 3 12-05-2006 02:06 PM
I need a part number. wickedclod Tamiya Txt-1 and Juggernaut 1 09-27-2006 04:38 PM
